Skyline Ztune
Jellybean
Yup I've come across that one, and drove that very car which is great news for me , lol!
That isn't a Z-tune though Carlo ;) Thats a V Spec II nur spec with z-tune kit, (notice lack of z-tune front fenders in the pic, have been since fitted by current owner).
This is the car also Carlo that's going to be on the mnc stand stand at modified motors in Cork I was telling you about.
Simply amazing is all I can say. It was owned by blow dog of the gtr owners club. I find it strange it's on a nismo site but I assure you its not a z-tune. Owned then by Nito in kent who was on here for a small bit as far as I know.
Spec copy/pasted from previous owners thread on car. Few more bits done now such as the z-tune wings and I think a v-cam pro has been fitted aswell.
Spec below:
Nissan Skyline GTR R34 2002 V-Spec II Nur
Engine - (Mapped to 8.5k rpm redline for reliability)
Top Secret Built HKS Step 2 RB28 Bare Engine (Rated to 900ps and 9k rpm)
Top Secret Cylinder Head Ported/Polished
Top Secret Studs
Top Secret Edition HKS Cam Pulleys
Top Secret Painted Rocker Covers
HKS Forged Pistons
HKS Steel Connecting Rods
HKS Steel Crankshaft (Step 2)
HKS 272in Step 2 Camshafts 10.2mm Lift (Trust Valve Springs)
HKS 272ex Step 2 Camshaft 10.2mm Lift (Trust Valve Springs)
HKS 1.2mm Metal Gasket
HKS Metal Intake Manifold/Throttle Body Gaskets
HKS Exhaust Manifold Headers
HKS GT II External Wastegate
HKS Wastegate Return pipe
HKS T04Z Turbocharger Conversion
HKS Kansai Carbon Fibre Spark Plug/Cam Pulley Cover
Trust Valve Springs
Trust Timing Belt
Nismo N1 Engine Block
Nismo Engine Mount set (3)
NGK Racing 8's Recessed Spark Plugs R7434-8
Aeroquip Pro Gold Teflon Lined Nomex Oil Catch Hoses
Aeroquip Pro Gold Rocker Cover Fittings
Intake and Exhaust System
HKS Super Power Flow Intake
HKS Polished Induction Pipe
HKS Polished Intercooler Entry Pipe
HKS Frontpipe 76mm
HKS Ti Muffler 102mm
ARC Titanium Straight Catalyst Replacement pipe 80mm
Nismo Balanced Intake Collector Plenum
Trust Greddy Polished Intake Pipe
Fuel System
HKS In Tank Fuel Pump
HKS 1000cc Injectors x6
HKS 11.0mm Fuel Rail
Aeromotive A1000 Fuel Pump p/n 11101
Aeromotive 10 micron post pump filter p/n 12301
Aeroquip Pro Gold Teflon Lined Nomex Braided Hose Feed (-12/ -10/ 2x -6)
Aeroquip Pro Gold Teflon Lined Nomex Braided Hose -6 Return Line
Abbey Motorsport Alloy "Tank Top Mount Plate" with Bulkhead Fittings
Abbey Motorsport Military Spec Fuel Pump Connector
Abbey Motorsport External Swirl Pot
Abbey Motorsport T-Piece Distribution Mini Swirl Pot
SARD Adjustable Fuel Pressure Regulator
Oil and Water Cooling System
HKS GT Bar and Plate Intercooler
HKS Thermostatically controlled Oil Cooling System
Trust High Capacity Oil Pump
Trust Large Capacity Baffled Sump Extension/Extended Oil Pickup
Trust Greddy Oil Filter Relocation Kit
Trust Greddy Front Diff Casing
ARC SMC55 Side Flow Super Micro Conditioner Water Radiator
ARC Air Remover Set
ARC Water Swirl Pot
Border Racing Oil Catch Tank
Nismo N1 Water Pump
SARD 68 Deg c Thermostat
Samco Silicone Lower Water Radiator Hose
Management and Electronics
HKS EVC V Electronic Boost Controller
HKS A/F Knock Amp with O2 Wideband/Knock Feedback
HKS F-Con V Pro Fuel & Ignition Timing Computer
HKS Mass Air Pressure Sensor 0-4Kpa
HKS BNR34 F-Con Wiring Loom
HKS Air Temp Sensor Harness
NTK Nissan Wideband Lambda Sensor
Defi VSD Concept
Defi BF Boost Meter
Defi BF Fuel Pressure Meter with differential pressure
Defi BF EGT
Defi Control Unit II
Transmission
Nismo G-Max Lightened Balanced Flywheel
Nismo G-Max Twin Plate Clutch (enlarged Spline version)
Nismo Getrag Large Diameter Input Shaft
Nissan Getrag 6 Speed Transmission
Chassis
Nismo G-Attack S-Tune HA Suspension System
Nismo LMGT4 Limited Alloys / Falken FK451's 265/35/18 Tyres
Nismo Titanium Strut Tower
Nismo Braided Steel Brake Hoses
Nissan N1 Brembo Twin Pot Caliper Rear
Nissan R33 Front Lower Wishbone Set
Sunline Racing Adjustable Tension Rod Set
AP Racing 6 Piston 362mm Brake Conversion Front
Ferodo DS2500 Brake Pads Front & Rear
Bodywork & Dress Up
Nismo Z -Tune Carbon Fibre Vented Bonnet with Forced Air Intake
Nismo Front Bumper
Nismo Side Skirts
Nismo Rear Skirts
Nismo Carbon Fibre Rear Spoiler Blade
Nismo Carbon Fibre Rear Diffuser
Nismo Style Carbon Fibre Front Splitter
Nismo Clear Repeaters
Nismo Oil Cap
Nismo Fuel Cap
Mines Carbon Fibre Aero Mirrors
Garage Defend Carbon Fibre Cooling Panel
Robsons Carbon Fibre Injector Electrics Housing
Augment Carbon Fibre Bonnet Damper Struts
ARC Water Radiator cap
ARC Air Remover pressure caps
Rays Air Valve Caps
Chrome Fuse Box Cover with Top Secret/HKS Logo
Interior
Nismo Steering Boss
Nismo Willans Race Harnesses x2
Nismo Titanium GT Gearknob
Nismo MFD2 Multi Function Display
Nismo Race Shut off Cigarette Lighter
Nur Interior (Black)
GTR Emblem Carpet Mats
Custom HKS A/F Knock Amp/EVC V Boost Controller Housing
Trust Greddy Twin A-Pillar Pod
Momo Race Steering Wheel
Must upload a few more pics of it.
