Guest MARKSSUPRA94 Posted June 26, 2009 Share Posted June 26, 2009 Hi.. The connector from the wires on my drivers side electric window broke..This is the one that connects into the switch..The wires are loose but can be connected to the connector on the switch..Does anyone know which wire goes where as i have no electric windows.. Mark Quote Link to comment Share on other sites More sharing options...
Homer Posted June 26, 2009 Share Posted June 26, 2009 Have the wires come out of the plug or is it something else? I can grab a pic or write them out here, but there a quite a few wires on that plug! Quote Link to comment Share on other sites More sharing options...
Guest MARKSSUPRA94 Posted June 26, 2009 Share Posted June 26, 2009 The connector on the wires broke that inserts into the connector on the following photo- Quote Link to comment Share on other sites More sharing options...
merckx Posted June 26, 2009 Share Posted June 26, 2009 (edited) Obviously check to see that you have the same colour wires as in the diagram below, I obtained the information from an online workshop manual. http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm This is a pic of the plug. Edited June 26, 2009 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest MARKSSUPRA94 Posted June 27, 2009 Share Posted June 27, 2009 Thanks for the diagram..Connected the colours accordingly and pressed the switch for the window to come down..It came a bit and stopped and the then when i went to start the car it wouldnt..When i turned the key the car was sparking but would not turn on..What might this be.. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted June 27, 2009 Share Posted June 27, 2009 The car should start without the windows working. You sure your battery isnt dieing/ been drained - perhaps if the loose connector was touching something? Quote Link to comment Share on other sites More sharing options...
Guest MARKSSUPRA94 Posted June 27, 2009 Share Posted June 27, 2009 The battery just got a full recharge..Cant figure out what it is.. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted June 27, 2009 Share Posted June 27, 2009 The battery just got a full recharge..Cant figure out what it is.. When is 'just'? I got a new battery and the car still kept going flat. Turned out that one of the leads to the battery was faulty and not connecting properly (hence not charging it) and the alarm was draining it. Quote Link to comment Share on other sites More sharing options...
Guest MARKSSUPRA94 Posted June 30, 2009 Share Posted June 30, 2009 There is no power goin to the windows and now my drivers seat is not working..what might this be.. Quote Link to comment Share on other sites More sharing options...
