cheekymonkey Posted June 25, 2009 Share Posted June 25, 2009 Hi All I know a lot you advocate stock wheels on the supra. I'm thinking of getting a set for track and/or drag use, and wondered what the advantages are? My 18s are 275mm wide on the back, does this give an advantage on drag strip / normal driving / or what? I always thought wider tyres = better grip but I guess this is not always the case. James Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 25, 2009 Share Posted June 25, 2009 Track wheels wont be any good on the drag strip and vice versa, you will need a set of each bud. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted June 25, 2009 Author Share Posted June 25, 2009 Track wheels wont be any good on the drag strip and vice versa, you will need a set of each bud. Yep that's kinda what I thought. So what would be better on the track - going thinner on the rear or keeping what I have? Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 25, 2009 Share Posted June 25, 2009 Yep that's kinda what I thought. So what would be better on the track - going thinner on the rear or keeping what I have? Id keep what you have for the street and track and get some weld 15" rear wheels for the strip like these:d http://s30.photobucket.com/albums/c338/jamie450x/?action=view¤t=welddragwheels007.jpg Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted June 25, 2009 Author Share Posted June 25, 2009 They look the business! Where'd you get them from, and what's the width on them? I have UK rear brakes though.. hehe Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 25, 2009 Share Posted June 25, 2009 My supe came with 16" rims. I got 2 sets of 17" rims, Volks and Works, for track use. Its now a track car and I have UK spec brakes to fit. I was going to put a wide tyre with a high profile on the stock 16" rear for drag use, if I ever get to a drag strip with it, and I was going to use the stock front rim and tyre on the back for any drifting I might get a chance to do. As far as I'm aware the stock 16" rear rims will clear UK rears and I'm hoping the stock fronts will do likewise. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 25, 2009 Share Posted June 25, 2009 (edited) They look the business! Where'd you get them from, and what's the width on them? I have UK rear brakes though.. hehe They wont clear uk brakes, im fitting j-specs just for the day. You can get them for websters. http://www.webster-race-engineering.co.uk/products.htm Edited June 25, 2009 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 25, 2009 Share Posted June 25, 2009 They wont clear uk brakes What won't clear Jamie? Front? Rear? BOTH?? Quote Link to comment Share on other sites More sharing options...
AlexM Posted June 25, 2009 Share Posted June 25, 2009 Stock 16" wheels won't fit over UK rears (or fronts), I tested it on Bignum's car at Llandow. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 25, 2009 Share Posted June 25, 2009 What won't clear Jamie? Front? Rear? BOTH?? 16" wheels defiantly wont clear uk brakes. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 25, 2009 Share Posted June 25, 2009 Ah nuts. I'm clutching at straws here I know but is it the lack of diameter that hinders fitment or is it an issue with the spokes because I have a nice set of hubcentric spacers at my disposal if they would help. Quote Link to comment Share on other sites More sharing options...
Chingy Posted June 25, 2009 Share Posted June 25, 2009 (edited) I have a nice set of hubcentric spacers at my disposal if they would help. with 25mm spacers you should clear the rear UK brakes, Edited June 25, 2009 by Chingy (see edit history) Quote Link to comment Share on other sites More sharing options...
