Frank Bullitt Posted June 25, 2009 Share Posted June 25, 2009 Just found this post on another Supra forum and thought it might be appreciated here as the exchange rate is looking a little better now HUGE SALE. 15%-25% OFF ALL in-stock Boost Logic Products. 15% Off Turbo Kits regularly priced at $3699 are now $3144.15 15% Off Fuel Systems usually priced at $1900 are now $1615.00 20% Off Fuel Rail Kit usually priced at $300 are now $240.00 20% Off Turbo Blankets usually priced at $150 are now $120.00 10% Off Built Auto Transmissions usually priced at $2200 are now $1980.00 25% Off 4" Downpipe and Midpipe usually priced at $899 are now $674.25 30% Off 4" Exhaust Systems usually priced at $899 are now $629.30 25% Off T6 FMIC (only the front mount, piping is available for BL T6 kits and VWR Intake Manifold) usually $1399 are now $1049.25 25% Off Boost Logic Timing Belt Tensioner Brackets usually $315 are now $236.25 15% Off Boost Logic NA-T Kits Stage 1 usually priced at $4499 are now $3824 and Stage 2 usually priced at $5349 are now $4546 10% Off NA-T Built Auto Transmissions usually priced at $1800 are now $1620 15% Off HKS SSQ BOV Flanges usually priced at $33 are now $28 20% Off 3" 2 Bolt Gaskets usually priced at $10 are now $8 20% Off 3" Cast Aluminum Elbows usually priced at $29 are now $23.20 20% Off 2.5" Cast Aluminum Elbows usually priced at $26 are now $20.80 20% Off 2" Cast Aluminum Elbows usually priced at $24 are now $19.20 T4 SS Inlet Gasket usually priced at $6 are now $5 Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 6, 2009 Share Posted July 6, 2009 thanks for the info i have a boostlogic T4 turbo manifold to go on a non-turbo. all i need is the manifold-to-head gasket. do you know if anyone sells these, i cant see it on the boostlogic site cheers Ray Quote Link to comment Share on other sites More sharing options...
kylestt Posted July 6, 2009 Share Posted July 6, 2009 that gasket would most likely be cheaper from Toyota local than over the pond mate Quote Link to comment Share on other sites More sharing options...
