Paul Whiffin Posted June 24, 2009 Share Posted June 24, 2009 As above, need a block or failing that an engine, I'll be boring the block out so doesn't have to be perfect. Link to comment Share on other sites More sharing options...
little num Posted June 24, 2009 Share Posted June 24, 2009 how much you wanting to pay, i have 1 with J+E pistons in. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 I only really need the block so wouldn't want the pistons and it needs to be stock bore size ideally. I dont mind buying a complete engine and use the head for spares though. Link to comment Share on other sites More sharing options...
MarkR Posted June 24, 2009 Share Posted June 24, 2009 What about the dude that's breaking the NA? That is the same block isn't it? http://www.mkivsupra.net/vbb/showthread.php?t=189650 Link to comment Share on other sites More sharing options...
MarkR Posted June 24, 2009 Share Posted June 24, 2009 Upside is that with an NA it won't have been pushed too hard. Link to comment Share on other sites More sharing options...
Terminator Posted June 24, 2009 Share Posted June 24, 2009 I think he may want oil ways ready for squirters, so a TT block. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 Yep, there not the same unfortunately. Link to comment Share on other sites More sharing options...
adnanshah247 Posted June 24, 2009 Share Posted June 24, 2009 paul i have a TT engine available. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 What you after for it? Link to comment Share on other sites More sharing options...
adnanshah247 Posted June 24, 2009 Share Posted June 24, 2009 1k. Link to comment Share on other sites More sharing options...
patrikbrunt Posted June 24, 2009 Share Posted June 24, 2009 L33 is selling a complete engine maybe worth a PM Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 I've PM'd him thanks. Link to comment Share on other sites More sharing options...
MarkR Posted June 24, 2009 Share Posted June 24, 2009 I thought some people close up the squirters on the drag cars? (slightly off topic) Link to comment Share on other sites More sharing options...
adrianstokes Posted June 24, 2009 Share Posted June 24, 2009 The castings are slightly different, the NA blocks are slightly lighter (must have less material) - though it is true that some of the drag racers in the US prefer to use the NA blocks without the squirters. I believe it increases oil pressure? If an NA block is any good to you Paul I've got a good one here that I can drop off when I collect the other bits? Let me know because I'll be weighing it in at the weekend. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 Thanks but no thanks mate. Link to comment Share on other sites More sharing options...
adrianstokes Posted June 24, 2009 Share Posted June 24, 2009 Thanks but no thanks mate. No problem, thought I'd ask anyway . If I come across anymore GTE lumps that I don't have requirements for I'll let you know ; keeping the ones I currently have. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 24, 2009 Author Share Posted June 24, 2009 No problem, thought I'd ask anyway . If I come across anymore GTE lumps that I don't have requirements for I'll let you know ; keeping the ones I currently have. Ok thanks Link to comment Share on other sites More sharing options...
dude Posted June 25, 2009 Share Posted June 25, 2009 I think he may want oil ways ready for squirters, so a TT block. Never looked in a NA block but dont the squrters get replaced with blanking plugs??? Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2009 Share Posted June 25, 2009 No, the casting is un-drilled and un-machined in the areas of the squirters. Link to comment Share on other sites More sharing options...
dude Posted June 26, 2009 Share Posted June 26, 2009 No, the casting is un-drilled and un-machined in the areas of the squirters. Hmm sure ive seen a block that had little blanking plugs installed, wonder what that was for???. Do any of the aftermarket pistons use the oil squirters??? Link to comment Share on other sites More sharing options...
MarkR Posted June 26, 2009 Share Posted June 26, 2009 Do any of the aftermarket pistons use the oil squirters??? I don't think they do. That's why I'm sticking to stock. If I change anything it'll be the rods. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 26, 2009 Share Posted June 26, 2009 Hmm sure ive seen a block that had little blanking plugs installed, wonder what that was for???. Do any of the aftermarket pistons use the oil squirters??? I so far as any piston will gain additional crown cooling from having the underside jetted with cooler oil, yes. In so far as do any forged pistons use a cooling gallery within the crown, like the stock cast pistons, no. The only forged cooling gallery pistons I've seen are the Tomei ones. I have those in my RB26 engine. Never seen any for the *JZ--GTE engines though. Link to comment Share on other sites More sharing options...
MarkR Posted June 27, 2009 Share Posted June 27, 2009 I wrote to Tomei yesterday to see if they had any with the cooling channel in the crown. Here's the response. "Hi Mark, Only our RB26 has the option of selecting the cooling channel pistons design (we have 2 types available for the RB26DETT). The 2JZ is without the cooling channel. Thank you -- Sincerely Allen Lorenzo TOMEI POWERED USA Inc. 13 Orchard Suite 107 Lake Forest CA 92630 USA Tel: +1 949-855-6577 Fax: +1 949-855-6525 http://www.tomeiusa.com [email protected]" So there you have it from Tomei........ Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 29, 2009 Author Share Posted June 29, 2009 Got one of these now thanks for everyone replying. Link to comment Share on other sites More sharing options...
Ryan.G Posted June 29, 2009 Share Posted June 29, 2009 Got one of these now thanks for everyone replying. Going 3.4 again? Link to comment Share on other sites More sharing options...
