nigelboyne Posted June 23, 2009 Share Posted June 23, 2009 hi lads is there any gain or worse by having the 2nd small electric fan running all the time Link to comment Share on other sites More sharing options...
Terminator Posted June 24, 2009 Share Posted June 24, 2009 Other than current draw I can't see any down side. Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2009 Share Posted June 24, 2009 i spoke to ryan about this when he mapped my car and he said the viscous fans are far better for cooling than 2 electric ones. Link to comment Share on other sites More sharing options...
paul mac Posted June 25, 2009 Share Posted June 25, 2009 i spoke to ryan about this when he mapped my car and he said the viscous fans are far better for cooling than 2 electric ones. i think he is on about the small auxilary air con fan, i cant see a problem leaving it on but if the engine required it, it would switch it on anyway so cant see much to be gained, if you want to improve the performance of the cooling system a full flush and new coolant would probably have a bigger impact Link to comment Share on other sites More sharing options...
nigelboyne Posted June 25, 2009 Author Share Posted June 25, 2009 yes the small aux fan. the larger one is permantely going correct Link to comment Share on other sites More sharing options...
Lee P Posted June 25, 2009 Share Posted June 25, 2009 There is no need to run the electric fan all the time, it comes on if the temp hits 97deg C or if the air con is switched on. Link to comment Share on other sites More sharing options...
nigelboyne Posted June 25, 2009 Author Share Posted June 25, 2009 ok cheers thanks Link to comment Share on other sites More sharing options...
