HKS Re-badged NGK !!??
sky
Guys ! Guys ! Are the HKS Iridium Sparks really NGK sparks re-badged . .!!!?????:eek: If so . .what should I go for in my next service !??? Also . .I've heard that the HKS mushroom style air filter isn;t really that good . .Was thinking about changing my K&N one ? Whaddya guys think ??
They are Denso plugs, but with an HKS part number and logo. I sell some special NGK colder grade plugs, e-mail me direct for info
[email protected]
My personal opinion of the HKS filters is unprintable, and i feel the stock air box and filter is none restrictive and works perfectly on both N/A and TT's, even fairly highly modded TT's.
Whilst I echo Chris' thoughts on the pod filters if you really want one, then IMO the best type are the cotton gauze mesh ones....the K&N being the best known reliable one....the Apex'i unit is also well rated and I believe has a higher flow rate than the K&N but that may be at the cost of filtration.
so ..should I hang on to my K&N one or change it . .to Apexi ? or HKS ?
I am assuming you currently have a K&N panel filter in the stock air filter box? If so, either stick with it or just use a stock paper filter element. IMO you will get zero gains from a K&N over a clean paper filter. I wouldn't touch a filter that replaces the stock air box myself, feel they are badly engineered ands a retrograde step. I am fairly unique in this matter though, but adamant nonetheless :-)
