Lee_e Posted June 21, 2009 Share Posted June 21, 2009 hey guys as you may of read my thread the other day about the ticking noise from the front drivers side. well i took the wheel off today and whilst checking the pads found they were pretty low and also a strange bumping noise when i spun the disc round and happened just as the groove past the pad, (if you get me) the guy before me changed the discs to drilled and grooved. i measured the disc and to me they look a bit too big, they measured 32mm width and the pads rub quite alot on the disc even in neutral. is this normal or should i think about getting some new discs aswell as pads ? thanks for any help Quote Link to comment Share on other sites More sharing options...
stupra Posted June 21, 2009 Share Posted June 21, 2009 Hi mate, i'm not sure on the width of the disc, but I had a small amount of noise, (like a ticking), when I had my slotted and dotted disc's, so I think that's normal . These type of disc's do eat the pad's a little quicker too. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted June 21, 2009 Author Share Posted June 21, 2009 ahh ok then , that helps a little bit but still i dont think there supposed to tick even when not applying the brakes. iv just seen a piccy of normal jspec brakes and they look the same (apart from the drilled and grooved bit) so i think it must be the low pads that are making the noise, iv got the pads already so will have a go at changing tomoz. Quote Link to comment Share on other sites More sharing options...
