Wrong brake discs?!
Lee_e
hey guys
as you may of read my thread the other day about the ticking noise from the front drivers side.
well i took the wheel off today and whilst checking the pads found they were pretty low and also a strange bumping noise when i spun the disc round and happened just as the groove past the pad, (if you get me)
the guy before me changed the discs to drilled and grooved.
i measured the disc and to me they look a bit too big, they measured 32mm width and the pads rub quite alot on the disc even in neutral.
is this normal or should i think about getting some new discs aswell as pads ?
thanks for any help
ahh ok then , that helps a little bit but still i dont think there supposed to tick even when not applying the brakes.
iv just seen a piccy of normal jspec brakes and they look the same (apart from the drilled and grooved bit) so i think it must be the low pads that are making the noise, iv got the pads already so will have a go at changing tomoz.
