JODY T Posted June 20, 2009 Share Posted June 20, 2009 Hey Im trying to repair my Loom ready for my engine, its knackered, its been cut up for a single install and im trying to fix it to run my TTs again.. I need help with the wiring colours for the two VSVs at the back of the Exhaust side of the engine (the left as you look at it..) Basically i know that each has a Red/Black wire, but could someone tell me the other colours? I need to know which colour does which VSV and where they are in the connector ie Black/Red on the left as its plugged in etc.. To make it easier a Photo might help if easier than describing.. can someone help asap? Im ready to do the work now so any help would be greatly appreciated Regards JT Quote Link to comment Share on other sites More sharing options...
JODY T Posted June 21, 2009 Author Share Posted June 21, 2009 Please help, Im stuck without it Quote Link to comment Share on other sites More sharing options...
heckler Posted June 21, 2009 Share Posted June 21, 2009 I think there Green/Red (which is the same as non vvti - so can assume vvti will be the same for the other wire) Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 21, 2009 Share Posted June 21, 2009 Hey Im trying to repair my Loom ready for my engine, its knackered, its been cut up for a single install and im trying to fix it to run my TTs again.. I need help with the wiring colours for the two VSVs at the back of the Exhaust side of the engine (the left as you look at it..) Basically i know that each has a Red/Black wire, but could someone tell me the other colours? I need to know which colour does which VSV and where they are in the connector ie Black/Red on the left as its plugged in etc.. To make it easier a Photo might help if easier than describing.. can someone help asap? Im ready to do the work now so any help would be greatly appreciated Regards JT I have a vvti wiring diagram, give me 5 mins... Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 21, 2009 Share Posted June 21, 2009 Blue-white Green-Black Green-Yellow Green-Red Green-Yellow Yellow-Black Quote Link to comment Share on other sites More sharing options...
vvteye Posted June 21, 2009 Share Posted June 21, 2009 Sorry Jody, I know it is my loom you're now suffering with, if it's any consolation, the car drove amazing at Llandow yesterday Quote Link to comment Share on other sites More sharing options...
heckler Posted June 21, 2009 Share Posted June 21, 2009 Sorry Jody, I know it is my loom you're now suffering with in that case Jody has no hope! Quote Link to comment Share on other sites More sharing options...
JODY T Posted June 21, 2009 Author Share Posted June 21, 2009 hmmm.. okay it looks like i know what colours go to each plug but not th orientation inside the plugs? Ive taken the plugs from a NA loom, on one plug the black/Red is on the left as you look at it and the other is on the right? So still need someone to look at there car if you can... many thanks its all appreciated Jody T Quote Link to comment Share on other sites More sharing options...
JODY T Posted June 21, 2009 Author Share Posted June 21, 2009 Sorry Jody, I know it is my loom you're now suffering with, if it's any consolation, the car drove amazing at Llandow yesterday in that case Jody has no hope! To be fair ive repaired all but these two connector blocks, it was a right mess but its sitting prety on the engine now Ill just have to hope it all works lol.. Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted June 21, 2009 Share Posted June 21, 2009 hmmm.. okay it looks like i know what colours go to each plug but not th orientation inside the plugs? Ive taken the plugs from a NA loom, on one plug the black/Red is on the left as you look at it and the other is on the right? So still need someone to look at there car if you can... many thanks its all appreciated Jody T Hi Jody If it's just the VSV wiring left (2 wires each) and you know which wires go to each VSV, you should be OK to have either orientation in the connector. As each VSV is a solenoid which isn't fussy on the direction of the current, the polarity shouldn't matter. Good Luck Andy Quote Link to comment Share on other sites More sharing options...
JODY T Posted June 21, 2009 Author Share Posted June 21, 2009 Yeah thanks Andy, I know what you mean.. I just wanted to repair the loom to Back to standard, Ie the way toyota did it.. I think i know the orientation but wanted someone to confirm visually with there own car.. If i know that there is 'Nothing' wrong with the loom, if i have any troubles i can discount at least the loom lol.. Quote Link to comment Share on other sites More sharing options...
