carl0s Posted June 17, 2009 Share Posted June 17, 2009 Do any cars use power assisted hydraulic clutches. If so is it common or uncommon? If the answer is no, then does that mean that a hydraulic clutch setup is pretty simple? When doing an engine & transmission swap, would the only potential issue be missizing of the master cylinder on the back of the pedal to the slave cylinder that activates the clutch? cheers Quote Link to comment Share on other sites More sharing options...
