michael parker Posted April 16, 2005 Share Posted April 16, 2005 Hi, just joined the club, this is my cherry popping post! I bought my 93 tt j-spec about 4 weeks ago through a jap importer in hemel hempstead, they do all the uk conversions etc... I spend a fair bit of time on the motorway and my cruise seems to only work up to 70 mph?? i know you shouldn't be driving over this speed but hey im only human, just wondered if they're limited as standard in japan, and if you can get it removed. Cheers Link to comment Share on other sites More sharing options...
Bobbeh Posted April 16, 2005 Share Posted April 16, 2005 You should be able to cruise way over 70. I do Link to comment Share on other sites More sharing options...
michael parker Posted April 16, 2005 Author Share Posted April 16, 2005 It wont let me set the speed to engage the cruise at 70+mph, i.e. press cruise on and set at 90mph, nothing happens! well annoying:-) Link to comment Share on other sites More sharing options...
Bobbeh Posted April 16, 2005 Share Posted April 16, 2005 Sounds like its not set up correctly, maybe something they didnt bother looking at or missed during the SVA. You get to speed, turn it on, tap the controller down, and its set. Link to comment Share on other sites More sharing options...
Fifty Posted April 16, 2005 Share Posted April 16, 2005 Hi Michael, welcome do a search for cruise m8 theres a lot of interesting stuff, including diagrams for wiring up if it was missed during conversaion; seems to be common. 50 Link to comment Share on other sites More sharing options...
michael parker Posted April 16, 2005 Author Share Posted April 16, 2005 It works fine below 70mph, so bit confused????? Link to comment Share on other sites More sharing options...
Jake Posted April 16, 2005 Share Posted April 16, 2005 You need to fit a decent quality speed converter, like the Thor one or do this mod : http://www.mkivsupra.net/vbb/attachment.php?attachmentid=1995 Link to comment Share on other sites More sharing options...
michael parker Posted April 16, 2005 Author Share Posted April 16, 2005 I,ve gotta converter fitted cause it reads in mph and odo goes up in miles, if it's a cheapy one, (which knowing what dealers are like to make a few extra quid) would that limit the cruise to 70 mph, i first thought it was maybe rectricted on the ecu???? Link to comment Share on other sites More sharing options...
Jake Posted April 16, 2005 Share Posted April 16, 2005 I bet your converter isn't wired to the cruise control though. Just do the mod in the pic I posted above and all will be well. Link to comment Share on other sites More sharing options...
michael parker Posted April 16, 2005 Author Share Posted April 16, 2005 I'll give it a whirl, or try!!!! Cheers. Link to comment Share on other sites More sharing options...
Vaughany Posted April 16, 2005 Share Posted April 16, 2005 Had the exact same problem on mine, cheap conversion I'm afraid. Pete Betts (Thor) fitted his speedo conversion and everything works fine now (Active Spoiler, Cruise) Give Thor a bell, believe me cruise control at 70+ is so much better. Link to comment Share on other sites More sharing options...
SimonB Posted April 16, 2005 Share Posted April 16, 2005 I,ve gotta converter fitted cause it reads in mph and odo goes up in miles, if it's a cheapy one, (which knowing what dealers are like to make a few extra quid) would that limit the cruise to 70 mph, i first thought it was maybe rectricted on the ecu???? It probably means your power steering is wrong too - it will think you're going slower than you are and give too much assistance. Get a Thor speed convertor and it will sort it. Link to comment Share on other sites More sharing options...
michael parker Posted April 16, 2005 Author Share Posted April 16, 2005 will look into the thor, cheers peeps!! Link to comment Share on other sites More sharing options...
Soop Dogg Posted April 17, 2005 Share Posted April 17, 2005 As everyone says, it's the converted speed signal that is mssing at the cruise control ECU. The limit on this is 110kph, so when it gets the converted signal, your new cruise limit should be around 110mph. Link to comment Share on other sites More sharing options...
Toms Supra Posted April 17, 2005 Share Posted April 17, 2005 where is the cruise control ECU?? Link to comment Share on other sites More sharing options...
michael parker Posted April 17, 2005 Author Share Posted April 17, 2005 Not too sure, tinkered about with previous cars, though dont fancy messing with this baby. hopefully gonna get this job done at slow dogs, along with cambelt and service, cheers for all the help evry1!! Im sure some1 will point you in the right direction as to the location of the "cc" ecu. Link to comment Share on other sites More sharing options...
