marbleapple Posted June 15, 2009 Share Posted June 15, 2009 Evening all I am after the following bits. Please pm me if you have any that may interest me. Needs: 1. Clear front indicators (I know of sites to get them but thought I'd approach members on here first 2. Bulb for rear 'strip' break light 3. New or very nearly new thrust bearing and bits around clutch (perhaps clutch also) Like if affordable: 1. Leather seats 2. Black carpet 3. Supra specific Boot enclosure for sub etc Link to comment Share on other sites More sharing options...
RobSheffield Posted June 15, 2009 Share Posted June 15, 2009 IIRC the rear strip light is a strip of separate LED's Link to comment Share on other sites More sharing options...
marbleapple Posted June 15, 2009 Author Share Posted June 15, 2009 IIRC the rear strip light is a strip of separate LED's Cheers Rob. Perhaps you can help Further? I thought I read some where that early jap N/As had 'fake' lights.... At the meet last weekend no one seemed to think that correct... Did I imagine that? Link to comment Share on other sites More sharing options...
RobSheffield Posted June 15, 2009 Share Posted June 15, 2009 Some (dont recall that its just NA's) have just the lens iirc, reasonably easy to open it up and have a look EDIT - its unlikely all the LED's have failed, unless its a fuse i would go with the 'empty' theory. Link to comment Share on other sites More sharing options...
Kev.O Posted June 15, 2009 Share Posted June 15, 2009 Cheers Rob. Perhaps you can help Further? I thought I read some where that early jap N/As had 'fake' lights.... At the meet last weekend no one seemed to think that correct... Did I imagine that? This is definately true for UK spec cars, not sure about imports though. Link to comment Share on other sites More sharing options...
Jamesy W Posted June 15, 2009 Share Posted June 15, 2009 Ric, have a go at dying your own carpet. It will take you no time at all, cost you no more than £20. I'm a total feck up with cars, and managed to do it in a weekend Link to comment Share on other sites More sharing options...
supradriver Posted June 15, 2009 Share Posted June 15, 2009 Cheers Rob. Perhaps you can help Further? I thought I read some where that early jap N/As had 'fake' lights.... At the meet last weekend no one seemed to think that correct... Did I imagine that? i think it was the UK that had the fake lights. Link to comment Share on other sites More sharing options...
marbleapple Posted June 16, 2009 Author Share Posted June 16, 2009 Ric, have a go at dying your own carpet. It will take you no time at all, cost you no more than £20. I'm a total feck up with cars, and managed to do it in a weekend HI Mate. I bought the dye.... problem is that my carpet is a bit of a mess and i'd need to spend some serious time getting it up to a standard where I actually want to dye it! Might be worth considering though mate. Does the dye remain 'fixed' in place? It doesn't start to come off on your shoes etc when it gets wet? Ric Some (dont recall that its just NA's) have just the lens iirc, reasonably easy to open it up and have a look EDIT - its unlikely all the LED's have failed, unless its a fuse i would go with the 'empty' theory. Cheers all re the rear brake light. So I need to check the fuse (you can guess the next question) and if not then I need to get Heckler or someone to make me a pretty new set? Is ti simply a matter of just pulling the cover off or do I need to go at it from inside the boot? Link to comment Share on other sites More sharing options...
RobSheffield Posted June 16, 2009 Share Posted June 16, 2009 So I need to check the fuse (you can guess the next question) and if not then I need to get Heckler or someone to make me a pretty new set? Is ti simply a matter of just pulling the cover off or do I need to go at it from inside the boot? You go in from the boot Link to comment Share on other sites More sharing options...
paul mac Posted June 16, 2009 Share Posted June 16, 2009 i have the rear seats in black leather you could have cheap, i'm in north west Lancashire so not a million miles away Link to comment Share on other sites More sharing options...
heckler Posted June 16, 2009 Share Posted June 16, 2009 On the brake strip - they are LED's and they DO fail. The units can be opened up to replace the LED's. The LED rear light has a power feed just after the brake light switch, so if the fuse had gone, none of the brake lights would work. Link to comment Share on other sites More sharing options...
Jamesy W Posted June 16, 2009 Share Posted June 16, 2009 HI Mate. I bought the dye.... problem is that my carpet is a bit of a mess and i'd need to spend some serious time getting it up to a standard where I actually want to dye it! Might be worth considering though mate. Does the dye remain 'fixed' in place? It doesn't start to come off on your shoes etc when it gets wet? Ric Once it's on mate, I won't come off! Just make sure to wear gloves when you do it. My carpet was looking a bit worn before I dyed it, I never even bothered giving it a steam clean, just a quick hoover and a couple layers of dye. Turned out a lot better than it was previously, still got half the dye on the garage floor though Link to comment Share on other sites More sharing options...
keron Posted June 17, 2009 Share Posted June 17, 2009 got some black leather seats for sale..in vgc...in the f.s section.. Link to comment Share on other sites More sharing options...
