Should I be worried??
pedrosixfour
Evening folks,
The power steering on my car is a little strange at the moment in so far as although it hasn't stopped working altogether it has become a great deal heavier while car is sat idling.
At the moment my entire dash is out of my car because I was getting a roll cage fitted, might the problem be due to the lack of signals from the dash to the power steering?
I know there are several other reasons for heavy steering but I can see no tell-tale leaks, hoses are all fine, fuse is ok. The only thing I haven't checked are the vacuum hoses, are these relevant on my car? ('95 SZ-R)
Thank you for any input.
I'm not Gav, I just haven't got around to re-fitting it yet. I'm building a track car so the dash came out to fit a weld-in roll cage. I was doing a few other bits and pieces on it and when I was moving it around I realised I couldn't just 'palm' the steering wheel as I could before.
Just want to know is there a possibility that the lack of a dash and cluster could be responsible for this unwelcome development in an already stressful build!!
Okay, fair point, I just had this image of a dashless car out and about on the road. :)
Once you reconnect up the speed sensor and the likes to the odo and the feed back to the ECU it should suddenly become a little easier :) If you aren't going to put the odo and speedo back in, you may want to consider connecting the feed up the ECU in a suitable way.
It'll all be going back in, thats a definite, once I paint the cage and possibily the interior.
I'm just glad to know there MAY be a chance this niggle could disappear with the dash re-installation.
Thanks for your time Gav, should all not end well I know where to find you!!
