michel lane Posted June 15, 2009 Share Posted June 15, 2009 Well i got the emanage mapped by ryan and its been running great , but then it starts to miss fire. so what i have done are: 1:crank sensor replaced 2:ignitor replaced 3:coil packs replaced 4: plugs replaced. 5:water temp sensor 6:air temp For some reason the car sometimes drives fine and some other times it misses really bad . I cant get my head around this. When i plug the stock ecu in , it runs a bit rich but it never misses when you are reving it . So i plug the em-blue back it , it starts and runs fine for about 30 min then it starts going wrong again . can anyone first : 1: tell me how it should be wired up , as when i wire it according to the manual it does not start at all . 2: how do i find the fault codes from it . this is the first time i have used this ecu thanks Quote Link to comment Share on other sites More sharing options...
bondango Posted June 15, 2009 Share Posted June 15, 2009 UK or JAP michel?? as the UK wont run if the Ignition harness is used (strange IGF feedback system not used on japs) Stock ECU throwing any codes? IIRC The active led on the Emanage unit should be steady green if there are no faults with it. Quote Link to comment Share on other sites More sharing options...
michel lane Posted June 15, 2009 Author Share Posted June 15, 2009 its a jap spec car Quote Link to comment Share on other sites More sharing options...
