alaing Posted June 15, 2009 Share Posted June 15, 2009 I have got this far with taking the bearing out of the offside rear hub, but i have come to a halt as i cannot drift the hub off?![ANGRY][/ANGRY] It says in the manual that u should use a slide hammer, i dont have one nither do i think it would work. Any suggestions plaese Quote Link to comment Share on other sites More sharing options...
alaing Posted June 17, 2009 Author Share Posted June 17, 2009 bumpski Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 17, 2009 Share Posted June 17, 2009 You are going to have to hit the inner part of the hub from behind, usually a large (impact) socket which will just fit through the bearing is the best/only thing to use. The real problem is trying to support the outer part of the assembly in a uniform manner so it doesn't shatter, deform or generally make a mess of the parking brake backplate and the disc brake stone guard. Quote Link to comment Share on other sites More sharing options...
brettjones Posted June 17, 2009 Share Posted June 17, 2009 sorry mate but when i did both of my rears last year i had to use a hydraulic press it took over 5 tonnes of pressure Quote Link to comment Share on other sites More sharing options...
paul mac Posted June 17, 2009 Share Posted June 17, 2009 sorry mate but when i did both of my rears last year i had to use a hydraulic press it took over 5 tonnes of pressure yep, take it to a machine shop and get them to press it out, they'll probably charge about a tenner and you'll still have all your fingers Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 17, 2009 Share Posted June 17, 2009 sorry mate but when i did both of my rears last year i had to use a hydraulic press it took over 5 tonnes of pressure yep, take it to a machine shop and get them to press it out, they'll probably charge about a tenner and you'll still have all your fingers Or you can take the sensible approach as mentioned above! (my way is more rewarding though, honestly) That being said I do have a 200 ton press sitting in the corner of the workshop should I decide its a lazy day. Quote Link to comment Share on other sites More sharing options...
alaing Posted June 17, 2009 Author Share Posted June 17, 2009 Ok guys thanks, thought it might come to a press! Quote Link to comment Share on other sites More sharing options...
