Guest mickmcl007 Posted June 14, 2009 Share Posted June 14, 2009 i dont have any lights on my dash , can anyone tell me how to fit new ones, also when i turn side lights on i cant see odo readins as it seems to go off cant follow trip mileage,,,,, Link to comment Share on other sites More sharing options...
supra steveo Posted June 14, 2009 Share Posted June 14, 2009 have u checked all fuses ? Link to comment Share on other sites More sharing options...
D8MOA Posted June 14, 2009 Share Posted June 14, 2009 could be the dimmer switch at fault? Link to comment Share on other sites More sharing options...
Homer Posted June 14, 2009 Share Posted June 14, 2009 Which lights specifically are not working, which ones are? As Damo mentions a dimmer switch disconnect or fault is the most likely cause of the main dash lights not working (instruments, heater controls, basically everthing that's set to dim with the headlights on) Link to comment Share on other sites More sharing options...
Guest mickmcl007 Posted June 15, 2009 Share Posted June 15, 2009 hi it seems ythat the dash board does not light up, cant see the speedo etc when its dark. Link to comment Share on other sites More sharing options...
supra steveo Posted June 15, 2009 Share Posted June 15, 2009 turn the dimmer switch up? Link to comment Share on other sites More sharing options...
