DSK Posted June 14, 2009 Share Posted June 14, 2009 Many questions come up regularly regarding brakes and related issues. I have listed some information below as it may be relevant to you and also fellow members. Excessive Temperature & Rapid WearFault; Friction material overheating and disc surface thermal cracks (blueing) Causes; Sticking brake calipers (sliders/piston seals), Axle/Wheel imbalance, Excessive prolonged braking (drag) Friction Material FracturesFault; Friction material cracks/fractures Causes; Pad restriction within caliper housing (flexing of pad/backplate(s)), impact damage during installation New Pads Fitted On Worn DiscsFault;Rapid wear, noise and judder Causes; Excessively worn/grooved brake disc surface Brake Disc Contamination Fault; Low brake efficiency Causes; Contaminated disc surfaces, (oils, solvents, cleaners) Uneven Pad Wear Faults; Uneven pad wear Causes; Poor alignment of brake caliper, poor alignment of brake disc/hub Fault; Uneven pad wear between 'inboard and outboard' pads Causes; Sticking brake caliper (insufficient lubrictaion of caliper sliders), worn/damaged piston seals Brake Noise & Judder Faults; Brake noise and judder Causes; Dirty wheel hub Brake Noise Faults; Brake noise Causes; Pads are tight in caliper (see scratch mark evidence on pad backplate edges). Uneven pad/disc contact, worn/grooved brake discs, excessively corroded brake discs. Recommended Maximum Disc Run-Out Good Practice; Always remember to check disc run-out before fitting new brake pads. (Maximum disc run-out on vehicle 01.5mm) Problems; Excessive run-out will cause noise, judder, uneven pad wear and poor brake efficiency. Brake Disc Damage Faults; Thermal Cracks (Blueing) Causes; Rapid pad wear, brake judder, vehicle vibration and brake noise. Brake Disc Failure Faults; Top Hat detachment Causes; Overtightening of wheel nuts (careful use of air pressure guns is required) Friction Material Detachements Faults; Friction material detachment Causes; Impact damage during pad removal/installation and/or excessive corrosion. Quote Link to comment Share on other sites More sharing options...
