Guest fj supra Posted June 13, 2009 Share Posted June 13, 2009 Sorry first of all , i know there are alot of threads about this subject , but i looked over them all and i couldnt get a clear enough answer , i have a stock 2JZ-GTE engine and i would like to add some cams , but the only ones available in my country are the HKS 272 in./ex. , so my question is do i go with them or do i go with something else ?? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 13, 2009 Share Posted June 13, 2009 You don't need anything that big, cams like that are better for Supra's fitted with a large single turbo. BPU would be your best bet for increasing the power of the car. After you have done that then you might want to consider 256/264 or 264/264 cams but on a stock engine it's just wasted money IMO. HTH Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 13, 2009 Share Posted June 13, 2009 Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2009 Share Posted June 13, 2009 in256/ex264 is generally considered as the best setup with stock turbos, don't go with the 272 cams. If you need a source for the cams I can supply what you need, drop me a pm if I can help. Quote Link to comment Share on other sites More sharing options...
