my "little" drift project....
neilthenut
  • 8 months later...
  • 3 months later...
I'm making progress
Panels will be painted soon
Water pipes all done
Single turbo on
W58 going soon...
Padel clutch on the way for new box
Fuel lines 60% sort of ish done
Going some work nest few weeks to chop /weld down pipe and wastegate
Brakes on and bleed
  • 2 weeks later...
Car has gone to local fabricator/ automotive guy.
Full exhaust inc down pipe
Some alloy welding jobs ( turbo water feed, an-10 fittings) fuel tank straps
Panels awaiting primer, then paint.
Almost everything is sat there ready to go on.
Just need a ecu.. ( thinking haltech or link)
And new harness.
- - - Updated - - -
Good on you! Dont give up - Just think of the fun once its done :)
Thanks, still enjoying my s13 to much to put effort into this
  • 1 year later...
  • 1 month later...
Wanting to get this back on track.
So Back collecting parts I need to continue. prop, inlet manifold and few other bits.
Gearbox flywheel and twin plate waiting to go in, after engine goes back in.
Fuel lines 90% ready.
Need new braided lines, as stock are not long enough with extra lock.
  • 1 year later...
Hi guys
So for long time club members, you'll know this has been a long one.
I've not given up, and in fact the progress has moved on but for whatever reason it's not letting upload pictures,
But car has moved on.
Engine gearbox brakes suspension all fitted
Car is ainted. Most of the windows are fitted, fuel system is now buttoned up.
It's ipaway from me for the second time in ten years, having some work I cannot do, smoke test inlet, turbo and some aluminium fab work.
Expectation is that it's on track April.
Thanks for reading. Will up load some pictures when I get car back.
  • Like 1
  • 1 year later...
