neilthenut Posted August 6, 2013 Author Share Posted August 6, 2013 Wohooo Trying to get some excitement back now, off to round 4 of BCD this wkd, so it should help..... Link to comment Share on other sites More sharing options...
neilthenut Posted August 7, 2013 Author Share Posted August 7, 2013 Link to comment Share on other sites More sharing options...
kwalker705 Posted August 7, 2013 Share Posted August 7, 2013 So started fitting brake lines, I wanted these to look right, not a fan of the nasty standard copper pipe, looks crap. Braided just is not practical to run complete front to back. S I came up with this [/Quote] and what exactly is "This" ?? reffering to the pipes specifically. Link to comment Share on other sites More sharing options...
magictorch Posted August 8, 2013 Share Posted August 8, 2013 Rubbish update....lol Link to comment Share on other sites More sharing options...
neilthenut Posted August 8, 2013 Author Share Posted August 8, 2013 and what exactly is "This" ?? reffering to the pipes specifically. It is my brake lines, not sure i want to share my secrete with you all! Simple, copper brake pipe, straighten, so it's perfectly straight, I hate wiggly brake pipe, then electrical heat shrink wrap. How's that? Looks a lot better than copper don't ya think? Rubbish update....lol Thanks Jamie. Ha Link to comment Share on other sites More sharing options...
neilthenut Posted August 8, 2013 Author Share Posted August 8, 2013 Link to comment Share on other sites More sharing options...
neilthenut Posted August 8, 2013 Author Share Posted August 8, 2013 Shots of the inter cooler, and radiator. They sit together, although there are separate units- The boost pipe routing, although not bad isn't perfect, what I so single turbo, who'll lop these of and have them redirected for better flow and easy of pipe, but will do for now happily The oem Toyota hose fits to the rad perfectly, top hose will be the challenging one, but not a massive problem, but require a filler cap, af supra has cap in radiator, and the cosworth has a header tank. Link to comment Share on other sites More sharing options...
neilthenut Posted August 8, 2013 Author Share Posted August 8, 2013 Last night completed the brake line that runs thought the car from the brake bias valve to the bulk head, Link to comment Share on other sites More sharing options...
neilthenut Posted August 8, 2013 Author Share Posted August 8, 2013 Brake line will be clipped in, but will do this at the same time as securing the wiring loom down. Link to comment Share on other sites More sharing options...
kwalker705 Posted August 9, 2013 Share Posted August 9, 2013 It is my brake lines, not sure i want to share my secrete with you all! Simple, copper brake pipe, straighten, so it's perfectly straight, I hate wiggly brake pipe, then electrical heat shrink wrap. How's that? Looks a lot better than copper don't ya think? yeaaaah.... knew thats what it was but asked anyway out of politeness. haha.... looks good actually. better than squint and buckled copper jobbies. Link to comment Share on other sites More sharing options...
neilthenut Posted August 9, 2013 Author Share Posted August 9, 2013 yeaaaah.... knew thats what it was but asked anyway out of politeness. haha.... looks good actually. better than squint and buckled copper jobbies. Cheers, I think... Yeah, another custom thing on my car, might not be putting mega bucks into it, but more custom bits and touches than some cars costing 4 times the amount.... Link to comment Share on other sites More sharing options...
neilthenut Posted August 14, 2013 Author Share Posted August 14, 2013 (edited) What a tool, air powered belt sander- used to clean up alloy plates and couple welds on frame in boot Few bits needed to put plates into boot, including my lunch, tesco value quiche , new air drill, and tiger seal! Edited August 14, 2013 by neilthenut (see edit history) Link to comment Share on other sites More sharing options...
neilthenut Posted August 14, 2013 Author Share Posted August 14, 2013 So, started fixing boot panels in, nothing special, drill and pop rivets. All so finished off the hydro handbrake, which involved making a bar with threaded ends to connect the master cylinder and the level. So long tube, chopped it to length Nut welded on, this shows it partly cleaned up, Adding male threaded end Welded on, shown with lock nut on Fitted up, well just need to get a bolt and replace the screw driver So, car is now on to 3rd grinder, fed up of it chewing power tools So first up tomorrow is a tidy up, things every where, and doing my nut in. Link to comment Share on other sites More sharing options...
neilthenut Posted August 18, 2013 Author Share Posted August 18, 2013 Started fitting the panels. Simp,y pop riveting them in, then I'll come back and seal them. Link to comment Share on other sites More sharing options...
neilthenut Posted August 18, 2013 Author Share Posted August 18, 2013 Little sneak peak of what I'm planning for the bonnet And yes, it will be functional, not just stuck on- Link to comment Share on other sites More sharing options...
Guest aspire Posted August 18, 2013 Share Posted August 18, 2013 pics of the quiche please Link to comment Share on other sites More sharing options...
neilthenut Posted August 18, 2013 Author Share Posted August 18, 2013 (edited) It's long gone now Edited August 21, 2013 by neilthenut (see edit history) Link to comment Share on other sites More sharing options...
Guest integrale8v Posted August 21, 2013 Share Posted August 21, 2013 Subscribed Link to comment Share on other sites More sharing options...
neilthenut Posted August 22, 2013 Author Share Posted August 22, 2013 Link to comment Share on other sites More sharing options...
neilthenut Posted August 22, 2013 Author Share Posted August 22, 2013 Jobs list, Breaking it down, means it look easy and hard all at the same time Link to comment Share on other sites More sharing options...
neilthenut Posted May 5, 2014 Author Share Posted May 5, 2014 So, Car now runs Loom is in and out being stripped/ shorted/ relocated Custom fuel tank and swirl pot are ready and located in car Fuel lines run on place, need fixing in Intercollegiate and rad are mounted Brackets for oil cooler have been made Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted May 5, 2014 Share Posted May 5, 2014 (edited) looks like a fun project be awsome to see this side ways :-D Edited May 5, 2014 by Hitbox Junkie (see edit history) Link to comment Share on other sites More sharing options...
JasonR24 Posted May 5, 2014 Share Posted May 5, 2014 Just read this project and it's been a long time coming hasn't it! look forward to the latest updates. Love the detail. Link to comment Share on other sites More sharing options...
neilthenut Posted May 5, 2014 Author Share Posted May 5, 2014 looks like a fun project be awsome to see this side ways :-D Just read this project and it's been a long time coming hasn't it! look forward to the latest updates. Love the detail. Thanks guys, yes, it has been an aweful long time, I'm on a mega tight budget, and when I have money, I have no time, and when I have time- I have no money! But it's getting closer to moving... Link to comment Share on other sites More sharing options...
neilthenut Posted September 28, 2014 Author Share Posted September 28, 2014 Work still continues ... Link to comment Share on other sites More sharing options...
