SupraShaun Posted June 11, 2009 Share Posted June 11, 2009 Hi all, I was just cleaning the engine bay and came across this loose hose: http://supra.sh-designs.biz/photo.jpg Its to the left of the charcoal canister, comes from the direction the arrow is pointing in, then goes up at a right angle. I've had a feel around under the intake manifold but cant find anything that it might plug into. Should it plug into anything or is it just a breather? Any help would be much appreciated Shaun Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted June 12, 2009 Author Share Posted June 12, 2009 Forgot to add, the car is a Jspec TT Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 12, 2009 Share Posted June 12, 2009 I'll have a look for you later when I'm messing with mine. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted June 12, 2009 Share Posted June 12, 2009 best get checking my hoses as of lately ive read a few loose hose threads Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted June 12, 2009 Author Share Posted June 12, 2009 I'll have a look for you later when I'm messing with mine. Thanks mate Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted June 13, 2009 Author Share Posted June 13, 2009 Quote Link to comment Share on other sites More sharing options...
suprasurrey Posted June 13, 2009 Share Posted June 13, 2009 Just had a look at my J spec TT. If this pipe is about 9mm bore with two 90 degree bends and is coming from the bulkhead It`s a breather pipe that should point downwards next to the cross member. Quote Link to comment Share on other sites More sharing options...
imi Posted June 13, 2009 Share Posted June 13, 2009 Just had a look at my J spec TT. If this pipe is about 9mm bore with two 90 degree bends and is coming from the bulkhead It`s a breather pipe that should point downwards next to the cross member. you mean the one that is located in the middle of the engine compartment and goes through the engine tray. Quote Link to comment Share on other sites More sharing options...
suprasurrey Posted June 13, 2009 Share Posted June 13, 2009 you mean the one that is located in the middle of the engine compartment and goes through the engine tray. I know the pipe you mean. The pipe I`ve found exits the bulkhead near the brake pipes and follows the contour of the cross member. This is much further back than the engine tray. Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted June 16, 2009 Author Share Posted June 16, 2009 Just had a look at my J spec TT. If this pipe is about 9mm bore with two 90 degree bends and is coming from the bulkhead It`s a breather pipe that should point downwards next to the cross member. Ah ok, thanks. So it looks like mine just needs twisting around as its pointing up at the moment. Quote Link to comment Share on other sites More sharing options...
