tonyhawk Posted June 10, 2009 Share Posted June 10, 2009 Ok, it has come to this and the beastie has to go It had a complete re-spray six months ago, engine rebiuld 3k ago and the valve guides a few days ago. The the main spec list is below, but what is not in the list is the Toad alarm with total closure and tracker unit. I'm sure there are lots of things I haven't remembered, but I'm happy to answer any and all questions I'm looking for £14k. In the spirit of complete honesty, there are a couple of things that are not 100%: the wheels are not perfect and two of them have some surface corrosion that needs treating; the only other defect is on the bonnet, which has two cracks at the front; I wanted to get them sorted, but I haven't been able to find a good body shop that can work with CF. To get both issues sorted would probably be about about £500ish, which is why it's not priced as high. Piccy's attached. Spec: Block:JE Pistons Bottom end lightened & balanced ARP Stud bolts ARP Rod bolts PHR Oil pump Cylinder Head: Polished/Ported/Gas Flowed Crower titanium valve springs & retainers HKS Inlet and Exhaust Cams (264 degrees) HKS Cam Wheels New valve guides Turbocharger, Induction & Cooling: Garrett GT358466R (not the GT35R, this has a bigger induction impeller) Boostlogic oil kit HKS Wastegate with screamer pipe Apexi Induction Kit HDi Intercooler HKS Dump valve ASI rad Fuel, Tuning & ECU: AEM EMS with 3.5 Map & Boost solenoid HKS DLI SARD 800cc Injectors SARD FPR FPD Bypass NGK BKR8 Plugs Bosch 044 fuel pump Exhaust: Reworked, re-welded and ported XS Power manifold XS Power downpipe XS Power midpipe HKS Superdragger rear box Drivetrain: RPS Flywheel RPS Street clutch Suspension, Wheels, Tires & Brakes: BBS 18" rims Yokohama AVS Sports (245 Front, 275 Rear) Engine Dress: Shiny Inlet Manifold Shiny Plenum Chamber Shiny Water pipe Shiny Fuse Box Cover Greddy Alloy pulley set Greddy top rad hose Greddy bottom rad hose Shiny coolant expansion tank Painted spark plug cover (same as car) Painted strut brace (same as car) Exterior: TRD Carbon Bonnet TRD Carbon Wing Top Secret front bumper Toyota side skirts Veilside wing mirrors Extras/Gauges/Toys: HKS Turbo timer AEM Wideband Sensor Defi Display with Exhaust Gas Temp, Oil Temp, Oil Pressure, Water Temp & Fuel Pressure sensors Performance: Mapping (by Ryan.G) was aborted due to a faulty oil line, a boost leak and some oil burn, which was preventing enough advance being added. However, in this unfinished state it still managed 533fwhp at 505ft/lbs All of these problems have been sorted (the oil issue was valve guides and have now been replaced), however I haven't taken it back to Ryan to be finished yet, but it should see 600bhp. Link to comment Share on other sites More sharing options...
Alex Posted June 10, 2009 Share Posted June 10, 2009 Looks good - a dyno with AFR's on it will always help settle any nerves about it for a prospective owner Link to comment Share on other sites More sharing options...
GazzaGSi Posted June 10, 2009 Share Posted June 10, 2009 Lovely motor and priced to sell imo. Excellent price for the spec even with the bits that need sorting Also, what is the resprayed colour? Was it a glass out jobby? Cheers Link to comment Share on other sites More sharing options...
tonyhawk Posted June 10, 2009 Author Share Posted June 10, 2009 Looks good - a dyno with AFR's on it will always help settle any nerves about it for a prospective owner Good point, I'll have to find it....it's in a box somewhere... I might get Ryan to finish it, I'd feel happier to sell it on completed rather than 'it should do this...' Link to comment Share on other sites More sharing options...
tonyhawk Posted June 10, 2009 Author Share Posted June 10, 2009 Lovely motor and priced to sell imo. Excellent price for the spec even with the bits that need sorting Also, what is the resprayed colour? Was it a glass out jobby? Cheers Ta. It needs to be seen in sunshine for the full effect as it's a deep graphite, but with metallic flecks of copper and green. It was a complete strip for the respray (Piccy's), everything was off! Link to comment Share on other sites More sharing options...
SupraAyf Posted June 10, 2009 Share Posted June 10, 2009 Now that’s a nice Supra – As people have already said though, get Ryan on the job and it should literally fly out of the window EDIT: How many miles mate? Link to comment Share on other sites More sharing options...
tonyhawk Posted June 10, 2009 Author Share Posted June 10, 2009 Now that’s a nice Supra – As people have already said though, get Ryan on the job and it should literally fly out of the window EDIT: How many miles mate? Cheers geez Ryan has done all of the mapping so far (on the original twins and the current single); the road tune is complete and it drives beautifully, the bit that needs finishing is turning the tubbie above 1.4bar. It has 65k on the clock. Link to comment Share on other sites More sharing options...
Bryson Posted June 10, 2009 Share Posted June 10, 2009 some more pics including some interior shots would be good Link to comment Share on other sites More sharing options...
tonyhawk Posted June 10, 2009 Author Share Posted June 10, 2009 Interior pics added to original post Link to comment Share on other sites More sharing options...
Sheefa Posted June 12, 2009 Share Posted June 12, 2009 Great car mate, super spec, super price and a trustworthy owner and a good forum member. I know where I'd put my money. Good luck with sale, easily worth it. Link to comment Share on other sites More sharing options...
tonyhawk Posted June 12, 2009 Author Share Posted June 12, 2009 Great car mate, super spec, super price and a trustworthy owner and a good forum member. I know where I'd put my money. Good luck with sale, easily worth it. Cheers for that, it means a lot to me. Link to comment Share on other sites More sharing options...
tonyhawk Posted June 15, 2009 Author Share Posted June 15, 2009 Spec list updated with a couple of minor things I'd forgotten. Link to comment Share on other sites More sharing options...
