Keefred Posted June 10, 2009 Share Posted June 10, 2009 I have searched on here and can find lots of threads about 02 sensors but not the actual part numbers. I have a 94 n/a auto and dont want to go into Toyota only to be told they cannot do them as it is an import or they need the engine number. Quote Link to comment Share on other sites More sharing options...
matthewm1965 Posted June 10, 2009 Share Posted June 10, 2009 (edited) Toyota 89465-19625 Denso 234-1055 Single wire type for early N/A HTH Matt Edited June 10, 2009 by matthewm1965 (see edit history) Quote Link to comment Share on other sites More sharing options...
Keefred Posted June 10, 2009 Author Share Posted June 10, 2009 Thank you very much. I have just had a copy of the fiche page faxed to me and it shows it as 89465. What does the second number 19625 mean ? and are there 1 of them or 2 ? I am sure I read on here the tt has one and the na has 2, but I cannot see a second one anywhere, not until the bottom of the exhaust downpipe which I think is 89425 which is shown as a 'sensor, exhaust gas temperature' Quote Link to comment Share on other sites More sharing options...
matthewm1965 Posted June 10, 2009 Share Posted June 10, 2009 The N/A has two O2 sensors. As far as I can gather, they are the same. Perhaps the lead length is different, but I am out of the country at the moment so can't check. I had trouble finding them in the UK. Had to order from the States. You can get universal ones easy enough, but they don't come with the correct Toyota connectors. I have also read bad reports about the universal type, so have stayed away from them and gone for OEM spec. Quote Link to comment Share on other sites More sharing options...
