Duffman Posted June 9, 2009 Share Posted June 9, 2009 Reckon mine has seen better days and may also have a leak. Rear passenger side Link to comment Share on other sites More sharing options...
Supranature Posted June 9, 2009 Share Posted June 9, 2009 You really need to change them in a pair You can get new ones here... https://sslrelay.com/buypartsby.co.uk/kyb-shock-absorbers-rear-details.php?recordID=2485 They seem to be rated quite well! Link to comment Share on other sites More sharing options...
Duffman Posted June 9, 2009 Author Share Posted June 9, 2009 You really need to change them in a pair You can get new ones here... https://sslrelay.com/buypartsby.co.uk/kyb-shock-absorbers-rear-details.php?recordID=2485 They seem to be rated quite well! Do you need to change them as a pair or is just better if you do so? Link to comment Share on other sites More sharing options...
Supranature Posted June 9, 2009 Share Posted June 9, 2009 Think the general concensus is that its a "must", although I'm no expert, Sean. As your car is BPU TT, then I wouldn't chance second-hand, never mind just one. The ones in the link are gas adjustables also, there was a post about them in the last month or so. Favourable comments were made. Link to comment Share on other sites More sharing options...
Duffman Posted June 10, 2009 Author Share Posted June 10, 2009 Came out this morning and the other rear was the same...although not quite as much fluid on the ground. Could it just be because it's been sitting on axle stands for 2 days so the shock is fully extented...would htis cause and fluid to leak out? Link to comment Share on other sites More sharing options...
