nevins Posted June 9, 2009 Share Posted June 9, 2009 Cars recently had its MOT and flew through it without any advisories as well, except I have an evil noise as if something is worn, it sounds like a clunk sound but the cars driving true and I just can't find this noise. If any one has had this themselves could you please give advice as it sounds as if it comes from the passenger side front and rear Quote Link to comment Share on other sites More sharing options...
ellis Posted June 9, 2009 Share Posted June 9, 2009 Rear subframe bolts? An oldy but a goody - they can become a touch loose and cause a banging underneath. Could also be brake pads in the caliper - does it happen more when reversing? Quote Link to comment Share on other sites More sharing options...
Nic Posted June 9, 2009 Share Posted June 9, 2009 When are you getting the noise? If it is when maneuvering at slow speed on full lock then as ellis says, the usual culprit is loose suspension or subframe bolts. Quote Link to comment Share on other sites More sharing options...
nevins Posted June 9, 2009 Author Share Posted June 9, 2009 its mainly when travelling along eg bumps in the road, i'v checked all the suspension and npthings loose Quote Link to comment Share on other sites More sharing options...
Supranature Posted June 10, 2009 Share Posted June 10, 2009 Try here, easiest things first. Noises are the most difficult things to explain/find/eliminate. Wait till your dash starts creaking.......... http://www.mkivsupra.net/vbb/showthread.php?t=35927 Quote Link to comment Share on other sites More sharing options...
