VVTI 6 speed manual conversion.
MarkR
I'm not going to be able to help massively mate, I can only shed light on my past experience with tip boxes. You are converting to manual so would assume that one of the sensors is redundant. On the tip box you'll have two sensors, one input one output. As far as I'm aware, the manual will just have one (output).
Thanks bud. I've read through about 30 docs today on Toyota boxes and it seems that the #1 sensor is the primary one. Only problem is that the manual box has power earth and pulse, but the tip box has 2 wires, so I'm not sure which one is the pulse. If I could figure out what colour a genuine 6 speed manual uses then I could find that wire on my ECU and hopefully start troubleshooting this there.
Thanks, spoke to Keron and he's going to check if he has the correct propshaft and also check on some of his engine harnesses to see what the wires look like.
Had one deal with Keron so far and was very impressed.
the more i hear about his work the more i like.
will defo be looking in his direction for a tt swap as soon as $ allows! ;)
I remember some Auto to manual wiring issues with DIY Dude Miko's tt swap thread it was a 5 speed but i think he had the same issue.
arr found it!!
http://www.mkivsupra.net/vbb/showthread.php?t=136136
If you can tell me where to look & take photos of, and if it's an easy anough area to get to, I don't mind trying to help.
Thanks Steve. I'm not sure how easy it is to get to when the box is on the car and all the bits are screwed together. I'll have to have a look and get back to you. Basically, the manual gearbox will have a few wires coming from it to the ECU. One of them is for the reverse indicator and usually there is a plug with three wires. If I remember correctly there is a power, earth and pulse. Ideally I'd like to know what colour the 3 wires are on the plug that isn't attached to the box, so I know what to look for on the ECU side.
arr found it!!
Yes, Keron is a very helpful chap :) Thanks for the link, but again, that was auto to manual and even though the tiptronic is the same box, it does a few things differently.
  • 6 years later...
