Supraman Posted June 8, 2009 Share Posted June 8, 2009 Fitting emanage and FCD still kicking in. When connection to appropriate MAP sensor feed car idles like a dog. Any ideas? Help! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 8, 2009 Share Posted June 8, 2009 Have you still got another FCD installed? if not have you setup the EMU FCD setup right? Are you using the Greddy MAP sensor and have you got it configured correctly? Quote Link to comment Share on other sites More sharing options...
Supraman Posted June 8, 2009 Author Share Posted June 8, 2009 Put the HKS FCD back in to see if it solved problem. Wiring for EMU was as per instructions but everytime tapped into MAP wire car ran like dog and would not idle. Thanks for getting back. Quote Link to comment Share on other sites More sharing options...
