Injector driver question
Terminator
When fitting a peak and hold driver, should the resistor pack be removed?
It makes sense to remove it as the extra resistance will slow the driver down by reducing the current to the injector.
To keep things tidy I want to replace the Resistor pack with the P&H driver.
Just need confirmation I have got this right.
Yes - resistor pack should be removed when fitted a dedicated flyback circuit like a peak/hold driver system. Does this PH driver have any software adjustment capability?
In some ways the resistor pack is a bit of a crutch to make up for a lack of PH driver and was typical practice a decade or more ago for low imp injectors. It works fine though. However, the PH driver should help get those big injectors open a little faster :)
