Guest bennyessex Posted June 8, 2009 Share Posted June 8, 2009 Advice needed guys - I have been told by a local garage that my aux belt tensioner is on its last legs. I can hear a continuous squeek which stops when I put the clutch in which seems to be coming from the drivers side near the front wheel arch. Anyone had this issue? Is it a home fix job on axle stands or am I best getting it done by pros? I understand they are about £150 from toyota? Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 8, 2009 Share Posted June 8, 2009 If it was your aux belt tensioner it wouldn't stop when you put your clutch in. Sounds more like a clutch release bearing. Quote Link to comment Share on other sites More sharing options...
TLicense Posted June 8, 2009 Share Posted June 8, 2009 Agreed the aux belt tensioner isn't effected by the clutch, if you said it got louder / quieter with revs than maybe. As Digsy said, look towards the clutch release bearing. Quote Link to comment Share on other sites More sharing options...
Guest bennyessex Posted June 8, 2009 Share Posted June 8, 2009 cool thanks for that, any ideas how much'ish it would be to get this sorted out? Quote Link to comment Share on other sites More sharing options...
