Project MUX - MX5 Turbo
Guest Garfy
  • Replies 61
Guest Garfy
I think I've met this car at an mx5nutz meet at a pub in Slindon back when I had my eunos maybe 18months ago?
It was a very nice looking car.
yeah I think you might have :) its been through some changes since then
  • 2 months later...
Time for an update, I few months ago I welded up the passenger side rear section of the sill, well this weekend has been set aside to sort out the drivers side, I knew this was worse than the other side, so I purchased a rear wing repair panel, so that I could cut off the bottom section and use that
This is what it looked like before I started, doesn't look to bad, well not as bad as some others I have seen
out comes the angle grinder, hmmmm, ok, still not toooo bad
now lets attack the lower part of the sill, oh dear, this is starting to look more serious
better investigate this further
Still not happy with what I see, better cut more of the rear wing away so I can see a bit more, and as you can see the strengthener is very rusty, and the rear of it is not attached to anything really, looks like its going to be a long day.
after a few mins looking at it, prodding it with a stick, uming and aring, I decide I might aswell start welding in plates and see what happens, first of all I wanted to secure the rear of the strengthener, so I make a plate using a cardboard template, put a fold on the back so to re-create the arch lip, which will then give me something to weld the outer wing to later, put a few more bends in it, then weld it in
with the rear of the strengthener secured and structurally sound I turn my attention to the bottom of the strengthener, a plate is made, and again I put a fold in it for the bottom of the sill, and few more bends, curves etc, and then its welded into place
now its all solid, and I'm really pleased with my work there, so on goes some rust protection
next I cut of the lower part of the repair panel, offering it up to the car a few times to make sure I cut off what I need
then, its welded onto the car, and cleaned up
then some filler to blend it in,
thats as far as I have got today, some more filler and sanding flat will be carried out tomorrow, then I'll respray it, all going well it should disapear as if by magic
so, if any of you out there have an MX5 with a bit of rust on your rear sills, I suspect it will be alot worse than you think, I am now considering looking at the passenger side again and cutting it right open as I have on this side, and repairing any nasties I see in there.
Hope you enjoyed :)
Yeah should be Interesting. :D
Were also looking at turbo'n it also, as it looks easy enough to do.
Where you getting your Kit from??
all over to be honest mate, have you been on MX5nutz? you should find everything you need to know on there
well, I've been at it all day, but its finished, I'm not 100% happy, again the colour is to dark, the car is supposed to be Velocity red, but its defo lighter than it should be, I think I'm going to respray the whole car next year, so this will do for now, I'll try and loose the colour difference along the door next weekend.
I did this with rattle cans to, I'll have to dig out the compressor before I do the whole car.
Interesting read mate! wish i had the tools and ability to weld, would definately be a useful skill to have.
all I will say is pick up a welder and give it a go, thats all I've done, no one has taught me how to do it, everything I've done to this car I have learn't as I've gone along :)
lovely car fella talking to you the other week has made me think about wether i need one lol
shame I couldn't have taken you out in it, that would have made you decide the answer to that question is a defo YES!!!! :)
  • 2 weeks later...
Another update, I managed to get my greasy little hands on a set of BMW E30 3 series bbs 15" alloys for the tiny sum of £80, and this is what I have done to them
velocity red rims, and gloss black centres, I'm also going to get some centre caps made up with bbr turbo on them, they will also be clad in new toyo proxes, mmmmm yummy, just need to find somewhere that will put the tyres on for me tomorrow
and to give some idea of what they might look like on the car
good read ive been following this thread, every time i read it it makes me want to get one even more to tinker with, there is a lovely one that attends our local jap car meets might see if i can pick a cheap one up over the winter.
wheels fitted, I'm really pleased, I think they look great, and the offset works excellently, not bad £86 including paint :) car is still sitting a little high in these pictures, but it will settle down.
Chrome mirrors have to go now though, lol
