Supraman Posted June 6, 2009 Share Posted June 6, 2009 4 wires coming from TPS: 1. Negative 2. 12V Positive 3. Wire going to ECU 4. Don't know what this does Two questions 1. What should the reading be off the yellow wire going to ECU from TPS (volts or resistance)...I'm getting no reading from this when changing the throttle position 2. What is the 4th wire (last wire next to yellow one) coming from TPS and where does it go? Would really appreciate a quick response. Thanks in advance for help. Link to comment Share on other sites More sharing options...
matthewm1965 Posted June 6, 2009 Share Posted June 6, 2009 I have never worked on the Supra TPS, but on the TPS on my Rover, the signal wire is a variable voltage, varying with throttle angle. I dont think it is the full voltage range, something like 0 to 5V IIRC. The 4th wire is an on/off signal to indicate when the throttle is in the closed position. HTH Matt Link to comment Share on other sites More sharing options...
Hermit Posted June 6, 2009 Share Posted June 6, 2009 Same on the Sup... when the throttle's closed, the 4th wire is grounded (if it's adjusted correctly...). Link to comment Share on other sites More sharing options...
Ian C Posted June 7, 2009 Share Posted June 7, 2009 The last wire (red?) is the throttle switch. As mentioned already, it lets the ECU know that the throttle is closed, which it uses for idle and overrun strategies (e.g. cutting the injectors). The yellow wire is the throttle angle, and it's a 0-5v signal although the range is usually about 0.6v to 4.5v. -Ian Link to comment Share on other sites More sharing options...
Supraman Posted June 7, 2009 Author Share Posted June 7, 2009 Same on the Sup... when the throttle's closed, the 4th wire is grounded (if it's adjusted correctly...). What do you mean "...adjusted correctly..."? and where is it grounded? Cheers Link to comment Share on other sites More sharing options...
Supraman Posted June 7, 2009 Author Share Posted June 7, 2009 Guys thanks for this help its really appreciated! Link to comment Share on other sites More sharing options...
Hermit Posted June 7, 2009 Share Posted June 7, 2009 What do you mean "...adjusted correctly..."? and where is it grounded? Cheers There's a switch inside the TPS which closes when the thrrottle closes, connecting '4' to '1' (using your numbering). '4' goes to the ECU, as 'IDL' I think. The TPS adjustment is done by rotating the TPS so that the switch closes at the right time. It's not something that usually goes out of adjustment by itself - more likely to happen if someone removes and refits it without adjusting it, because refitting it in what looks like the exact same position is unlikely to get it right. It's a fiddly job! Link to comment Share on other sites More sharing options...
Hermit Posted June 7, 2009 Share Posted June 7, 2009 Some docs in these posts... http://www.mkivsupra.net/vbb/showpost.php?p=615754&postcount=2 http://www.mkivsupra.net/vbb/showthread.php?t=43765&highlight=throttle Link to comment Share on other sites More sharing options...
Supraman Posted June 7, 2009 Author Share Posted June 7, 2009 There's a switch inside the TPS which closes when the thrrottle closes, connecting '4' to '1' (using your numbering). '4' goes to the ECU, as 'IDL' I think. The TPS adjustment is done by rotating the TPS so that the switch closes at the right time. It's not something that usually goes out of adjustment by itself - more likely to happen if someone removes and refits it without adjusting it, because refitting it in what looks like the exact same position is unlikely to get it right. It's a fiddly job! Thanks for clarifying! Link to comment Share on other sites More sharing options...
Supraman Posted June 7, 2009 Author Share Posted June 7, 2009 Some docs in these posts... http://www.mkivsupra.net/vbb/showpost.php?p=615754&postcount=2 http://www.mkivsupra.net/vbb/showthread.php?t=43765&highlight=throttle Tried to download the 2nd link but reporting a corrupt file. Is there another link to this doc? Cheers for the help. Link to comment Share on other sites More sharing options...
Hermit Posted June 7, 2009 Share Posted June 7, 2009 Tried to download the 2nd link but reporting a corrupt file. Is there another link to this doc? Cheers for the help. Yep, it's linked to in the second thread ('... overlap ...') Link to comment Share on other sites More sharing options...
Supraman Posted June 7, 2009 Author Share Posted June 7, 2009 Yep, it's linked to in the second thread ('... overlap ...') Ah! Cheers Link to comment Share on other sites More sharing options...
Supraman Posted June 8, 2009 Author Share Posted June 8, 2009 Pulling my hair out here. Getting the following error codes intermittently: 31 - Intake air pressure sensor/vacuum sensor signal abnormal 41 - Throttle position sensor abnormal 47 - Throttle position (TP) sensor 2 - short/open circuit I'm confused as I haven't tapped into these fitting the emanage though have fitted 3 bar sensor and harness. Any ideas guys? Link to comment Share on other sites More sharing options...
Supraman Posted June 8, 2009 Author Share Posted June 8, 2009 Ignore last post found fault. Was duff connection at ECU Link to comment Share on other sites More sharing options...
