RLTC Map/DAT
hiten55
Just replied to you pm, file waiting, with your name on it:)
Do you know if the configuration routine was done? If not, no dat will work. You can just jack the car up, spin the wheels by hand in live log and work out which channel is connected to each wheel. To be honest this is often the easiest way to do it as some times the system wont confirm the settings, so it is a bit of a gamble to trust that the system has set itself correctly.
Edited by Terminator (see edit history)
