Equator, weight
tbourner
Further from the centre of the Earth should mean less gravity?
Agreed, but you are not further as you are still on it (if you follow), but there is a greater pull from the earth in a parallel manner to your body, due to a greater concentration of matter.
Do you weigh less on the equator than at the North Pole, due to the centrifugal force?
Weight is only to do with Gravity. But i quess it would seem lighter
I presume you could way slightly more or less depending on where you are in the world but it will be irrelevant in the grand scheme of things.
Another silly question where the results would be negligible
Hmmm, interesting question, there is also the possibility that you weigh more due to there being more earth mass generating more gravity.. perhaps they cancel each other out :)
True, but you would be further away from the centre of the earth (where the density is at it's greatest) therefore the gravitational pull would be less.
I was quite intrigued to find out that... a friend of mine, who studied physics at uni and now has a degree in it.. he works as an engineer for some posh aircraft company... the first thing they were taught in uni was that centrifugal force doesnt exsist. Only the principal does...
If you fill a bucket with water... cut a whole in the bottom of it.. and then swing it in a circle really fast... you would expect the water to fall out the bottom.. but it doesnt.
All the way through uni, all of his lecturers spent their time convincing people that it doesnt exsist.... lol
Hmmm, disagree there...gravity does not originate from an infinitly small single point, but is rather a collective force from the cumulative mass. This is starting to head into quantum physics where it all gets very interesting.
I'd actually be interested to know what the answer is, as all my comments are purely from the scientific knowledge I've gained over the years and could possibly be incorrect.
I thought it was the same amount of matter but at different density, due to it being 'squashed'? So you're further away from the centre but with the same 'mass' as you would have beneath you at the poles.
It would have fallen out before you even began swinging it, surely :)
Yep it does, it will go straight out the hole
But there is no such thing as centrifugal force - it is for explanatory purposes only although though an opposite force does exist Centripetal Force
You raise an interesting point there... which possibly negates my theory. This might require some research :)
Nah, it has not been physically squashed, just has that appearnce - density variation throughout the earth is insignificant
Anyway, I have to go
Bye!
And yes I agree, but what I said still applies whether it was squashed or stretched or whatever.
Do you weigh differently at the North Pole than what you do at the equator?
Yes you do, because at the equator the centrifugal force due to the spinning of the Earth is at its maximum, and vanishes at the poles. This means that the attractive force of gravity is slightly reduced because it is directed towards the center of the Earth, while the centripetal force is directed outward from the center. The effective acceleration of gravity at the poles is 980.665 cm/sec/sec while at the equator it is 3.39 cm/sec/sec less due to the centrifugal force. If you weighed 100 pounds at the north pole on a spring scale, at the equator you would weigh 99.65 pounds, or 5.5 ounces less. Your mass, in grams, however would stay the same because 'grams' is a measure of the resistance of a body to being moved and has nothing to do with acceleration or gravity. Your mass in kilograms would remain the same. It is common for people to use 'pounds' and 'grams' interchangeably but they are not.
From NASA's site
http://image.gsfc.nasa.gov/poetry/ask/a11511.html
I retract my previous statements because they are WRONG! :)
From NASA's site
The NASA answer doesn't say anything about the distance from surface to centre, but that adds to the effect. As other people have said, the earth bulges at the equator (like me) and so anyone there is further away from the Earth's centre of mass.
The gravitational force is inversely proportional to the square of the distance between the centres of mass of the two bodies (the earth and the person standing on it in this case).
