twinkle001 Posted June 5, 2009 Share Posted June 5, 2009 hi i know you all had a laugh with me last time and i can take a joke but i really need to know why my o/doff keeps flashing on the dash it dosnt do it all the time but most of the time please no silly answers like i had when i asked what the red button was for i need to know if i am doing something wrong or it needs to be fixed i look forward to your reply's:search: Link to comment Share on other sites More sharing options...
Digsy Posted June 5, 2009 Share Posted June 5, 2009 Check your error codes. Probably a code 42. Does the check engine light come on too? Link to comment Share on other sites More sharing options...
twinkle001 Posted June 5, 2009 Author Share Posted June 5, 2009 no nothing else comes on Link to comment Share on other sites More sharing options...
Dnk Posted June 5, 2009 Share Posted June 5, 2009 (edited) does the o/d on or off switch actually work ? Edited June 5, 2009 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Guest blueangel Posted June 5, 2009 Share Posted June 5, 2009 my mates does this too always has and the management light comes on Link to comment Share on other sites More sharing options...
Mike_Mac Posted June 5, 2009 Share Posted June 5, 2009 As Dnk's said - if your O/D buttong doesn't work then it'll probably be a fault with the button's cables - they can snag and break in the gear lever, or the connector under the gear lever may have loosened. If your O/D works then it'll probably be a code 42 as Digsy said - which could be a loose speed sensor on you gearbox, or again a connection in the dial binnacle. Search for code 42 and you'll get lots of hits. If it's the O/D switch then a new one isn't too much from Mr T. Link to comment Share on other sites More sharing options...
