Help please!!! Uk front caliper pins
96sz
Help! I am trying to remove the pins from the front calipers but they are stuck solid. I have managed to get one out, but the other three i have ended up sawing in half, result, 3 half pins stuck in the rear of the calipers!:( I have tried hammering them with no luck and am worried i could damage the calipers.
Any suggestions how i could get these ******`s out?
Thanks
Thanks
Have you taken the calipers off the car?
Edit: Sorry, see below
Edited by Paul (see edit history)
If off the car then have you got any access to a fly press? If so then easy to use a pin punch and the press to shock it out.
If not then support the caliper on a socket or similar placed on a solid hard surface, get a pin punch and club hammer and shock it with decent swipes.
Repeated light hitting won't touch it, the caliper will be fine if correctly supported.
Edit: If you're using any old piece of metal as a punch then this won't help either as it'll just mushroom at the end and absorb the impact from the hit.
Plusgas would be better as it's a penetrating oil however it's down to how well and how sudden the shock from the hit is.
If they are off the car then that's easier, support on something like a socket.
what are you using, a normal hammer and an old pin to smack them out?
Yes, hammer and old pin. The ends have been mushrooming but i have been de-burring them with a small craft tool.
Problem is that the hammer is too lightweight and the pin is absorbing the blow!
Any mates work in engineering or is there a small engineering shop nearby? they will more than likely have a small fly press.
I ended up cutting mine in half and pulling one half through the normal direction and the other half was knocked through the other way using a steel rod.
Thats what i have done. 1 more out so far today so only 2 more to go then i can start cleaning them ready to paint.:)
