boost vaccum
sup_dawgTT
hey guys
first time posting in the UK forums but iv been on the supraforums community awhile. just a question please, iv just hooked up by boos gauge following the MKIV.com guide and is only reading vaccum. it reads 20 vaccum on idle, but then under load it reads around 11 vaccum and under full boost it goes to 0. any ideas why? iv hooked it up to the vaccum pressure sensor line using a T piece.
thank you
Ash
Hey Sup_Dawg. Whereabouts in NZ? I'm in Auckland. Should meet up sometime.
IMHO for stock it'd be hard to even get into boost on 1st gear. Stick it on 2nd or 3rd and go up a hill somewhere.
Otherwise, perhaps a boost leak?
hey guys, yup its on stock twins lol i should have mentioned that. i did sit and rev it i saw vacuum increase which was a sign that the gauge was registering something so i thought ok everything running fine lets take it out for a boost. upon driving the gauge does move up to 10 vacuum, and stays there under load of the first turbo, upon planting it it moves to 0 or 1 positive pressure. i have no leaks but ill change the vacuum hose tomorrow and try again. should i just hook it up from the FPR line instead? since thats how the GReddy manual installs it?
im positive since i followed the MKIV.com instructions which was take the line from the pressure sensor. but now im thinking maybe take the FPR line instead? im not sure about the gauge but it reads fine. its reading negative vacuum pressure upon warming up, but it wont move over to the right hand side and show positive boost pressure. any help please? how would i do a boost leak test?
i used the T piece i got in the box which featured a two way connection and the third part had a brass or some sort of metal fitting inside i think which is a one way valve? but anyway it has a metal fitting which said to connect the boost gauge line into and connect the boost pressure line into the two ends that run straight across.
I would expect vacuum to increase with load if it didn't have a turbo.
Nope. Manifold depression will be high at idle and will gradually approach atmospheric pressure as the throttle opens.
I'm confused by this, why would it approach atmospheric pressure? If the engine is under load the pistons pull air in hence the sucking noise from the induction kit. That would surely register as a vaccum?
As for the problem at hand, i would agree with the others and say fooked boost gauge. Does the stock gauge read positive pressure? Could you try the feed from that?
No, because the throttle is wide open so there is very little resistance against the flow of air and hence very little vacuum.
i have an auto gauge lol so its a bit crap but should work, i might take it back tomorrow to see if its working but im reading positive psi but only around 1-2 psi which is strange under full boost is it not? theres no leaks i checked today and yesterday, o Marmoot flick me a txt [removed by mawby]
Please send private information like phone numbers via PM.
Little vacuum = vacuum though :p
I know the only resistance is from the air filter but it would still be a negative pressure, regardless of how little.
About 2kPa (or 0.3PSI) - hence "approaching atmospheric pressure".
The inlet depression at idle will be greater because the pistons are trying to suck 3 litres of air every two revolutions against an almost fully closed throttle.
You will still hear a sucking noise from your induction kit because between the air filter and the turbo inlet it is sucking - even when on boost. We are talking about pressure (or vacuum) inside the manifold. When you are at full load the manifold pressure will be positive in a pressure charged engine, or virtually atmospheric on an NA. At idle they wil both register negative manifold pressure.
Edited by Digsy (see edit history)
so i should be seeing a relatively strong amount of positive pressure once accelerating? im getting 1-2 psi under heavy throttle use where my foot is almost reaching the floor. im not sure why, i hope its the gauge but could it be a bad tune? i havent gotten the car tuned so its stock but i have replaced the turbos? that could be the problem? i do admit the original pair of turbos did feel to pull harder.
Surely the figure would depend on how restrictive the filter is? Or is the 0.3 a measurement without the filter in place?
