Guest Decat man Posted June 2, 2009 Share Posted June 2, 2009 Hi all and a big hello from a new member... changing the rear offside wheel bearing on my 95 TT and need to remove the rear disc, hub nut off, drive shaft able to slide but disc still wont move... am i missing something?.... thanks for any help anyone can give Quote Link to comment Share on other sites More sharing options...
mawby Posted June 2, 2009 Share Posted June 2, 2009 Hand brake. You need to insert a screwdriver into the hole (should be protected by a rubber cover if I remember) on the disc and turn it.... I can't remember what direction either but probably anti-clockwise, and this will adjust the hand brake such that the disc can be removed. Don't keep tugging it at like I did as you'll bend the adjustor out of shape and then it'll foul the disc when it's put back on. Quote Link to comment Share on other sites More sharing options...
heckler Posted June 2, 2009 Share Posted June 2, 2009 you'll find that the disk will also be seized on. There are some small threaded holes you screw a bolt into to help release from the hub - goes with quite a BANG! Quote Link to comment Share on other sites More sharing options...
Guest Decat man Posted June 3, 2009 Share Posted June 3, 2009 Many thanks for that... Sounds a plan Quote Link to comment Share on other sites More sharing options...
EdMorris Posted June 3, 2009 Share Posted June 3, 2009 Just done this myself. Mine were really seized on. If the screw technique alone does not shift them then a few hard hits on the disc with a soft face mallet should help. It did for me. As a side the threads are M8 x 1.25 thread. Also, when you wind the brake shoes in via the plug, it needs to go all the way in a downwards direction. The adjuster is at the '6' position if you imagine a clock face, so line up the plug here and you'll be able to see it/turn it. Quote Link to comment Share on other sites More sharing options...
movistar Posted June 3, 2009 Share Posted June 3, 2009 (edited) The discs will be the least of your worries if your changing your wheel bearings...did mine the other week, both sides...what a B*tch!! your gonna need a press and a bloody big drift, good luck :-) as you can see here http://www.mkivsupra.net/vbb/showthread.php?t=186652 Edited June 3, 2009 by movistar (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Decat man Posted June 5, 2009 Share Posted June 5, 2009 Big thanks to all who posted... Discs off... now the fun part... again cheers and thanks. Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted June 5, 2009 Share Posted June 5, 2009 Hand brake. You need to insert a screwdriver into the hole (should be protected by a rubber cover if I remember) on the disc and turn it.... I can't remember what direction either but probably anti-clockwise, and this will adjust the hand brake such that the disc can be removed. Don't keep tugging it at like I did as you'll bend the adjustor out of shape and then it'll foul the disc when it's put back on. i did that as well smashed the shyt out of the disc with a hammer until it came off along with the entire mechanisms lol Quote Link to comment Share on other sites More sharing options...
Guest Decat man Posted August 4, 2009 Share Posted August 4, 2009 Having changed both an my god those ball joints are something else without wreckin them a Sealey VS3802 28-55mm fits all the ball joints an doesnt screw the rubbers a small 20 tonne workshop press did the bearing no worries.. better than smacking stuff with hammers. Quote Link to comment Share on other sites More sharing options...
