intake manifold
madmarf
just a quickie guys
anyone know if the TT intake manifold fits on the N/A without trouble? if not whats the faults?
does the TT injectors and rail drop in on the n/a with the new manifold or are the resistor packs needed? wireing modified?
iac and throttle cable need changing?
anyone got one lying around?
cheers
Edited by madmarf (see edit history)
From memory although Im not 100% but i think the lower plenum is the issue. I think the TT version uses a different head pattern to the NA.
You could get hold of a TT intake and lower plenum.cut the TT and lower plenums in half and then weld the 2 seperates together to form a hybrid NA - T.
If that makes sense ?
I may have an intake and plenum in the shed, i will check later on today.
TT intake manifolds have been put on n/a's quite allot over in the states. I've seen it done on clubna-t.com. Might be worth a look
nice bud, ill give them a check out ;)
thanks bud, if you got a complete one ill apreciate it ;) beer for you [GRIN][/GRIN]
Well i dug some bits out the shed. it appears to be a complete TT intake and lower plenum. It was previosuly used by me for some porting and polishing practice so the ports have been opened up to match the radius of the gasket as well as smoothing the casting.
If you cover courier postage i will send them out to you. Pm me your address if you want said bits.
Colin
