door price
erol_h
If you're desperate you can PM me. I have a spare set of door cards in the loft. They have non-standard speaker grills though.
Thanks for that mate the car is going to be repaired through the insurance and just trying to see if it will be close to a write off.
depends how much damage there is. I put together a rough estimate for a member on here a while back so i can do this for you if required
thanks for that mate already took the car to toyota and they are going to send me a quote through. The damage is to the drivers door, rear spat, rear wing, the paint around the door frame is cracked aswell.
2nd hand is the only way for door bits. A stock door card is £620 from toyota, doors about the same. Last time I paid £30 for an entire door (including window, electrics, etc), and £40 for a door card. Finding a good one is the hard part.
