dazla Posted June 1, 2009 Share Posted June 1, 2009 Think i'm going to try and clean up my head lights to get rid of the yellowing, i've done search on what cleaning stuff to use. Brasso, some say T-Cut, others say Megiuar's Scratch-X Which is the best to use and do i just use a rag or is there any light sanding involved. Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 1, 2009 Share Posted June 1, 2009 I Tcut mine about 4 times, brought them up a treat Quote Link to comment Share on other sites More sharing options...
Scott Posted June 1, 2009 Share Posted June 1, 2009 Think i'm going to try and clean up my head lights to get rid of the yellowing, i've done search on what cleaning stuff to use. Brasso, some say T-Cut, others say Megiuar's Scratch-X Which is the best to use and do i just use a rag or is there any light sanding involved. It all depends what extreme you want to go to. Brasso, T-Cut and Scratch-X all do pretty much the same thing. I went with scratch-x as its designed for this kind of application. If you want to do it right you will need to take the lenses out so that you can do the inside. I would recommend using some fine grit sandpaper lubricated (1500-2000 grit) just to get a bit of a cut. From there you move onto your polishes, you would probably need a polisher to do a decent job though. You would be there forever by hand. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 1, 2009 Share Posted June 1, 2009 if your gona do it proper i have a guide to taking out the lense and cleaning up etc here http://www.mkivsupra.net/vbb/showthread.php?t=186797 Quote Link to comment Share on other sites More sharing options...
dazla Posted June 1, 2009 Author Share Posted June 1, 2009 It all depends what extreme you want to go to. Brasso, T-Cut and Scratch-X all do pretty much the same thing. I went with scratch-x as its designed for this kind of application. If you want to do it right you will need to take the lenses out so that you can do the inside. I would recommend using some fine grit sandpaper lubricated (1500-2000 grit) just to get a bit of a cut. From there you move onto your polishes, you would probably need a polisher to do a decent job though. You would be there forever by hand. Theres no way i'm attempting to do the insides, thats to technical for me. I'll just try the fronts first. When you say lubricated, just water will do right? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 1, 2009 Share Posted June 1, 2009 Theres no way i'm attempting to do the insides, thats to technical for me. I'll just try the fronts first. When you say lubricated, just water will do right? Yeah water is fine. If your not taking them apart don't expect miracles though Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 1, 2009 Share Posted June 1, 2009 if thats the case mate i could do them for you? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 1, 2009 Share Posted June 1, 2009 i used ferecla g3 with a mop and plenty of water and they come out looking like glass (almost) it fades again in time but once a month with a mop and g3 and they look sweet Quote Link to comment Share on other sites More sharing options...
dazla Posted June 1, 2009 Author Share Posted June 1, 2009 if thats the case mate i could do them for you? The hole take apart thing and oven job, And how much would one be wanting for the job. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 1, 2009 Share Posted June 1, 2009 well you dont wont the insides painting do you? Quote Link to comment Share on other sites More sharing options...
dazla Posted June 1, 2009 Author Share Posted June 1, 2009 well you dont wont the insides painting do you? No just the yellowing. How many have you done mate Quote Link to comment Share on other sites More sharing options...
supra_si Posted June 1, 2009 Share Posted June 1, 2009 i use autosol, metal polish on mine. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 1, 2009 Share Posted June 1, 2009 PM'd Quote Link to comment Share on other sites More sharing options...
