trinitom Posted June 1, 2009 Share Posted June 1, 2009 Need some help here people! today i noticed a strange tapping noise coming from the viscous fan section! this is what i found!! Quote Link to comment Share on other sites More sharing options...
jacko Posted June 1, 2009 Share Posted June 1, 2009 Looks like you found that just in time! Has it been rubbing on anything? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 1, 2009 Share Posted June 1, 2009 wow, think you have been lucky there you have caught it before it went. Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 1, 2009 Author Share Posted June 1, 2009 The belt is half sized, anyone have any ideas on what could be doing this! Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 1, 2009 Share Posted June 1, 2009 id say 99% the tensionor bearing failing Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 1, 2009 Author Share Posted June 1, 2009 Looks like you found that just in time! Has it been rubbing on anything? yep lucky!! i believe there is something rubbing, but not on top! must be something on the bottom! Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 1, 2009 Author Share Posted June 1, 2009 Nice, now i have something to do on the Next days! Now that i need to remove the belt, there is something else that i should replace apart from belt and bearing? Thanks Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 1, 2009 Share Posted June 1, 2009 tensionor itself Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 1, 2009 Author Share Posted June 1, 2009 tensionor itself yes sure! i say something else like oil pump water pump etc Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted June 1, 2009 Share Posted June 1, 2009 Hi mate I would say it was the tensioner as well it happened to my Mr2 Turbo the exact same as yours with all da bits as well bearning was faulty You got it just in time you lucky lucky person id say 99% the tensionor bearing failing Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 4, 2009 Share Posted June 4, 2009 I don't think the 2jz engine has intrusive valves anyway. So if the belt did snap, It would'nt damage the engine. Quote Link to comment Share on other sites More sharing options...
dibbleyuk Posted June 4, 2009 Share Posted June 4, 2009 I don't think the 2jz engine has intrusive valves anyway. So if the belt did snap, It would'nt damage the engine. That is correct mate Quote Link to comment Share on other sites More sharing options...
Ric Posted June 4, 2009 Share Posted June 4, 2009 Might aswell do the water pump while you are there Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 6, 2009 Author Share Posted June 6, 2009 well some updates. Yesterday I have removed all the stuff to get access to timing belt and what i have found is quite impressing! 1st problem: the crank pulley bolt was so lose that can be turned by hand! and because of this the crank pulley have now a crack on the inner edge probably duo to vibration! 2nd problem: The timing belt tensioner bolt was over torqued by the previous owner or who have it changed , that the tread on the oil pump is completely fooked, this cause the tensioner bolt get lose and damaged the timing belt. (it nearly make a hole on the water pump casing!!) Now solutions for this: Get new or used good condition crank pulley. And About the oil pump I can get a new one, or mea by repair this one by welding the hole and make new tread, but honestly I’m more for a new one! And for the previous owner i must say this is a complete MONKEY JOB for who have changed the timing belt last time!! (without offending) pics: cleaned all the mess done by the belt. water pump nearly damaged by the belt Crank pulley crack and damage done by lose bolt! damaged tread on the oil pump that supports the tensioner. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 6, 2009 Share Posted June 6, 2009 I would try and get the oil pump re tapped mate. I believe it's a huge job to replace the pump, so I would try a cheaper re-tap first, especially if there is nothing wrong with the pump itself. With regard to the crank pulley, look at it like this, at least you found the pulley problem out before it decided to jump ship of its own accord at 5000rpm . It looks like the original crank pulley anyway so could do with being changed. Once it's all back together, you'll get a nice feeling of smugness, safe in the knowledge that your new shiney crank pulley is good for many many years to come Quote Link to comment Share on other sites More sharing options...
trinitom Posted June 7, 2009 Author Share Posted June 7, 2009 I would try and get the oil pump re tapped mate. I believe it's a huge job to replace the pump, so I would try a cheaper re-tap first, especially if there is nothing wrong with the pump itself. With regard to the crank pulley, look at it like this, at least you found the pulley problem out before it decided to jump ship of its own accord at 5000rpm . It looks like the original crank pulley anyway so could do with being changed. Once it's all back together, you'll get a nice feeling of smugness, safe in the knowledge that your new shiney crank pulley is good for many many years to come Quote Link to comment Share on other sites More sharing options...
