JamieP Posted April 25, 2010 Share Posted April 25, 2010 Thanks mate. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 25, 2010 Share Posted April 25, 2010 (edited) Ive never heard of a scatter shield before! Looks great Dude. Are you gonna try and iron out the misfire at the Pod? Edited April 25, 2010 by Swampy442 (see edit history) Quote Link to comment Share on other sites More sharing options...
dude Posted April 25, 2010 Author Share Posted April 25, 2010 Ive never heard of a scatter shield before! Looks great Dude. Are you gonna try and iron out the misfire at the Pod? I dont think it will missfire with the engine back in the car dude, but we will see. Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted April 25, 2010 Share Posted April 25, 2010 That NOS setup looks insane Quote Link to comment Share on other sites More sharing options...
dude Posted April 25, 2010 Author Share Posted April 25, 2010 That NOS setup looks insane It will go to 600hp if the need arises, all depends how much Mr JP decides to spend:eyebrows: Will be a weapon with the 3.4 and T6 frame turbo and the NOS Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 25, 2010 Share Posted April 25, 2010 Lol, im not trying to keep up with you mate, i think we are after different things, i want the ultimate street setup. Quote Link to comment Share on other sites More sharing options...
dude Posted April 25, 2010 Author Share Posted April 25, 2010 Lol, im not trying to keep up with you mate, i think we are after different things, i want the ultimate street setup. Mines a road car !!!!!Honest I have to tax it next week:innocent: Just now im a grandad I prefer my comfort so use the Range Rover most of the time. Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 Induction side is almost there, the inlet to the TB will need cutting and welding but that is quite simple. The fuse box base had to be cut out and it now sits over the throttle cable wheel. Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 Bomex is only going to need a slight trim and thats only to allow room for the spray bar, nitrous purge lines are all done in aeroquip hose (not plastic lorry air line stuff) and exit in the bottom/side vent either side of the Bomex. Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 Prop is on, nice adaptors so it can use big meaty HS joints at either end. Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 Prop Hoop now needs cutting and final welding etc to make sure it sits in the right place to catch the prop Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 may also make another bracket for the Toyota centre mount mount that turns that into a hoop. I am going to measure the prop and get some made up in steel with the ally adaptors, these props use an american flange and Hardy Spicer joint so should be easy enough to source andthe joint is easily replaceable. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 26, 2010 Share Posted April 26, 2010 might be my eyes but is that prob carbon fibre? Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2010 Author Share Posted April 26, 2010 might be my eyes but is that prob carbon fibre? Yes dude, its the 'big boy' carbon prop, I will get spares made in steel or alluminium as the carbon is very expensive. PW was trying to do a group buy which made em cheaper. A 2 piece with rubber donuts is asking for trouble on a car that should have the power we are expecting, also being fitted this week will be the Billet diff cover and uprated drive shafts and one off mega strong wheel studs otherwise the breaking point just moves further down the line. The whole point is to be able to launch the car with as much force as poss and not hold back, remember 1/10th sec on the launch is 3/10ths off the 1/4 mile, so 3/10ths off the launch is allmost 1 sec off the 1/4 mile time. Quote Link to comment Share on other sites More sharing options...
Project Blitz Posted April 26, 2010 Share Posted April 26, 2010 DUDE- what an amazing build i defo look forward to seeing this beast! Quote Link to comment Share on other sites More sharing options...
dude Posted April 28, 2010 Author Share Posted April 28, 2010 Breather system all on Quote Link to comment Share on other sites More sharing options...
dude Posted April 28, 2010 Author Share Posted April 28, 2010 IC pipes all fitting, we managed to get these so that the ends of each pipe IC etc virtually touch, Paul spent 5 hours cutting and welding the turbo housing and oulet pipe to get a perfect fit. Quote Link to comment Share on other sites More sharing options...
hodge Posted April 28, 2010 Share Posted April 28, 2010 Is that a vac reference on the front of the catch tank. Just curious why you would need a vac reference and 2 filters I thought it would only need either / or. Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 28, 2010 Share Posted April 28, 2010 Is that a vac reference on the front of the catch tank. Just curious why you would need a vac reference and 2 filters I thought it would only need either / or. Overflow pipe i bet, if a piston lets go that catch can will soon fill up. Quote Link to comment Share on other sites More sharing options...
tDR Posted April 29, 2010 Share Posted April 29, 2010 Standard breather systems on Toyotas of the era usually have a vac provided by the intake to help pull the vapours out of the crank case - Toyota done that for a reason so I think best to mimic it with aftermarket catch can setups. Questionable whether it was done for emissions, possibly to help the turbos etc. but usual thinking in the performance world is to junk the return to intake as oil vapour into the engine is effectively lowering the octane of the burn - instead vent breathers to atmosphere. I have seen vapour scourge systems where the breathers are plumbed into the turbo downpipe to really pull out of the crankcase and I think b'have might have done this to his over here? In fact looking at the pic dude may have done this here? Looking mighty impressive dude, can't wait to see you run with this setup.... then get bored and fit a proper drag box to run the times it should really be doing Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2010 Author Share Posted April 29, 2010 Standard breather systems on Toyotas of the era usually have a vac provided by the intake to help pull the vapours out of the crank case - Toyota done that for a reason so I think best to mimic it with aftermarket catch can setups. Questionable whether it was done for emissions, possibly to help the turbos etc. but usual thinking in the performance world is to junk the return to intake as oil vapour into the engine is effectively lowering the octane of the burn - instead vent breathers to atmosphere. I have seen vapour scourge systems where the breathers are plumbed into the turbo downpipe to really pull out of the crankcase and I think b'have might have done this to his over here? In fact looking at the pic dude may have done this here? Looking mighty impressive dude, can't wait to see you run with this setup.... then get bored and fit a proper drag box to run the times it should really be doing Cheers, Brian. If the yanks can run low 8's with a 6spd then so should we:eyebrows:, The cage is only legal to 8.5 anyway:blink: Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2010 Author Share Posted April 29, 2010 Diff going together Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2010 Author Share Posted April 29, 2010 Front back together Quote Link to comment Share on other sites More sharing options...
Branners Posted April 29, 2010 Share Posted April 29, 2010 tow bar fitted? good to see another beast coming on. Are you doing TOTB this year? Quote Link to comment Share on other sites More sharing options...
supradibbs Posted April 29, 2010 Share Posted April 29, 2010 Not sure if you have already said about this but whats with the two FPRs Quote Link to comment Share on other sites More sharing options...
