jevansio Posted July 12, 2009 Author Share Posted July 12, 2009 I will Dan but sadly it's already sold Link to comment Share on other sites More sharing options...
dandan Posted July 12, 2009 Share Posted July 12, 2009 Balls! Looking good - I like the fuel rail cover piece, that tidies things up nicely on that side. Link to comment Share on other sites More sharing options...
jevansio Posted July 12, 2009 Author Share Posted July 12, 2009 Cheers bud, yeah it does clean that bit up, I'm gonna make a plate to go between the rail & plenum to tidy that bit up too Link to comment Share on other sites More sharing options...
dandan Posted July 12, 2009 Share Posted July 12, 2009 Sounds good. You may have mentioned this already...did you have to hack into, and then extend, the wiring for the ignitor or was there enough slack to relocate it? Link to comment Share on other sites More sharing options...
jevansio Posted July 12, 2009 Author Share Posted July 12, 2009 Sounds good. You may have mentioned this already...did you have to hack into, and then extend, the wiring for the ignitor or was there enough slack to relocate it? I'm goning to have to extend it, not by much though, there's enough to get it to the inner wing, just I'm going to put it in the passenger footwell so I'll need another 6 - 12 inches depending on where I bolt it Link to comment Share on other sites More sharing options...
Wez Posted July 12, 2009 Share Posted July 12, 2009 Looking good Link to comment Share on other sites More sharing options...
Luxluc Posted July 12, 2009 Share Posted July 12, 2009 Very nice Jay Link to comment Share on other sites More sharing options...
Kev.O Posted July 12, 2009 Share Posted July 12, 2009 No worries, you might find the first time you push it on it won't go, just keep trying, it does go & once on is super tight PS be interested if you find a nice way to tidy the corners, I did it in 4 strips one for each side, I also tried running one length all the way round. I'm on the look out for something to tidy the corners up. Well I'm used to cutting trunking at 90 degrees bends, which usually good tidy so I'm sure I'll sort something out Link to comment Share on other sites More sharing options...
dandan Posted July 12, 2009 Share Posted July 12, 2009 Bit of a random question Jay - how much louder was your car when you changed to the 4" DP and MP? Link to comment Share on other sites More sharing options...
jevansio Posted July 13, 2009 Author Share Posted July 13, 2009 Bit of a random question Jay - how much louder was your car when you changed to the 4" DP and MP? Dunno yet, it's not fired up yet Link to comment Share on other sites More sharing options...
dandan Posted July 13, 2009 Share Posted July 13, 2009 Aha I see - I didn't realize you hadn't had chance to check it out yet. Link to comment Share on other sites More sharing options...
dandan Posted July 20, 2009 Share Posted July 20, 2009 Jay - I don't suppose you have any pics like this one before the downpipe was wrapped do you? I'm trying to work out (before buying) if I can modify a 4" combo to suit my cast manifold install... Link to comment Share on other sites More sharing options...
jevansio Posted July 20, 2009 Author Share Posted July 20, 2009 Dan, at the moment the downpipe has had all the heatwrap taken off so if you wanted a photo I could easy snap one. basically same shot as before but without any heatwrap? Link to comment Share on other sites More sharing options...
dandan Posted July 20, 2009 Share Posted July 20, 2009 I've just pm'd you to save clogging up your thread. (Should have done that to start with) Link to comment Share on other sites More sharing options...
MarkR Posted July 20, 2009 Share Posted July 20, 2009 Any updates? Link to comment Share on other sites More sharing options...
jevansio Posted July 21, 2009 Author Share Posted July 21, 2009 Not yet, waiting on stuff, need my rad rewelding & waiting on turbo, at a standstill Link to comment Share on other sites More sharing options...
jevansio Posted July 25, 2009 Author Share Posted July 25, 2009 Small update, got the bosses rewelded on the radiator, so that is all back together & fitted. Got some small mikalor clamps for the rad pipe so that's all jubilee clips gone. Started work on the fusebox. My old one was destroyed so I bought a new bottom and made a bracket and refitted it. Also sprayed & lacquered the fusebox tops (I'm not great at spraying so will prolly get them redone when I get the car resprayed). Dan (DanDan), I took some photo's of the downpipe, TBH you can't see a lot (it's too dark). There is loads of room around the downpipe mostly. It is very close to runner #6 (but obviously you won't care as you're using a cast manifold). Also it's pretty close to the firewall (but as I don't yet have my midpipe fitted it's hard to tell as it could move). Anyway here's the pics I took: Link to comment Share on other sites More sharing options...
JamesC Posted July 25, 2009 Share Posted July 25, 2009 It's coming on well Jay, look at the difference between start and now: Link to comment Share on other sites More sharing options...
MarkR Posted July 25, 2009 Share Posted July 25, 2009 That's really starting to show all the hard work! Good man! Link to comment Share on other sites More sharing options...
JamieP Posted July 25, 2009 Share Posted July 25, 2009 Before and semi finished shot is great, love what you have done with hiding a lot of the wires. Link to comment Share on other sites More sharing options...
Luxluc Posted July 25, 2009 Share Posted July 25, 2009 Great work Jay. Where have you transferred the HKS DLI to? Link to comment Share on other sites More sharing options...
jevansio Posted July 25, 2009 Author Share Posted July 25, 2009 (edited) Many thanks chaps, yeah those shots do show the progress well. HKS DLI is going into passenger footwell, I'm holding off cutting any more loom until the turbo turns up, I want to start the car to check all wiring so far is OK before extending any more to reduce any fault finding I may have to do PS, this is how she looked at the start of the year when I pulled it out the garage after the winter Edited July 25, 2009 by jevansio (see edit history) Link to comment Share on other sites More sharing options...
MarkR Posted July 26, 2009 Share Posted July 26, 2009 What a great improvement! Link to comment Share on other sites More sharing options...
MRX Posted July 26, 2009 Share Posted July 26, 2009 Good job mate, looks like a lot of time and effort has been put in and the results speak for themselves! Link to comment Share on other sites More sharing options...
supra dan Posted July 26, 2009 Share Posted July 26, 2009 top job looks clean Link to comment Share on other sites More sharing options...
