Muffleman Posted May 30, 2009 Share Posted May 30, 2009 Thinking of replacing my wastegate, anyone tried the Synapse ? http://www.synapseengineering.com/ http://www.turbomagazine.com/tech/0705_turp_synchronic_wastegate/index.html Thinking of giving one a try Quote Link to comment Share on other sites More sharing options...
Wez Posted May 30, 2009 Share Posted May 30, 2009 Just read through that, interesting. Although if you have a correctly controlled traditional wastegate I dont see what you will gain. The idea of electronic boost control is increase the cracking pressure as they call it and provide steady boost levels. If you have no electronic control and are looking for a mechanical solution these could be a better solution. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted May 30, 2009 Author Share Posted May 30, 2009 Yeah seems interesting. I have the AEM and a mac valve controlling the boost, but I have a wastegate problem so thinking of changing from the old HKS60mm to something else. Not too badly priced either compared to a Tial 44mm. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 30, 2009 Share Posted May 30, 2009 AEMs and MAC valves can work very well with the HKS GT60mm, I use to run that exact setup when I was AEM and still use the same MAC valve and wastegate with the Solaris ECU. Whats your issue? Quote Link to comment Share on other sites More sharing options...
Muffleman Posted May 30, 2009 Author Share Posted May 30, 2009 Wont boost past wastegate spring, it's probably something simple but haven't had chance to take the wg off Dude checked the pipework and it all looked okay, so need to pull the wg off and have a look Terry was up couple of weekends ago and mentioned the Synapse wg's, so wondered if anyone had tried one Quote Link to comment Share on other sites More sharing options...
csa Posted June 4, 2009 Share Posted June 4, 2009 I had that exact problem too. are you sure your mac valve is working correctly? mine wasn't Quote Link to comment Share on other sites More sharing options...
SupraHuman Posted June 8, 2010 Share Posted June 8, 2010 See it in a 3000hp car: ,been reading a lot about this WG lately, as muffleman said, anyone got any experience with this WG?? Looks to be a decent kit. Quote Link to comment Share on other sites More sharing options...
