Warning light but no probs
ADD
Good afternoon all, i had a warning light come up today on the car it was the far right orange one of a car with its lights flashing under the mileage clock. any ideas what this could be? i have searched.
Just re checked them all and nothing is blown :banghead:
The foglight is built into the rear cluster
Then it must be one of the relay components within the fog light conversion. They are there to stop the "blown bulb" scenario which you now have.
Check all the connections to the conversion.If they seem ok, then one of the relays used to "trick" the system has gone.
...far right on the left hand set of warning lights?...that means 'rear light failure', i have that problem myself, it must be my fog lights, i have a Japanise import with fog light switch fitted under the steering wheel to get car to U.K spec...realy should get that sorted out myself, hopeflly just a bulb, does anyone no what one it is though? i dont fancey leaving car in reverse then jumping out to see if my reverse lights are ok...that'd be silly:blink:
