Power Steering Problem?
Supe
Just replaced the Power steering pump with a second hand one.
The pump was whining, so bled the system with the wheels off the ground and it was smooth and quiet again, however, after lowering the car back on the ground, I am left with no power steering at all :(
Anyone shed some light please :)
Thanks guys, I changed all the fluid and there are no leaks in the system.
After bleeding the system four times with the wheels off the ground, I think I am getting somewhere :rolleyes: the power steering has come back to life and the froth in the reservoir seems to have dissappeared :)
I will only be able to tell, if all is good or not after a test drive, currently the car is parked up behind two other cars, so can't be bothered to go out tonight. If the problem continues I will report back :)
p.s. another thing I noticed is the pump seems to have a 'ticketty/tappetty' noise (If that makes sense?).
As my engine sounds extremely smooth at idle and there are no other noises, this is very noticeable, even although it is not very loud :confused: I bought the used pump from a member on here.
Again thanks for the input guys, takes the stress off a bit when I'm working on the car myself :)
