Terminator Posted May 28, 2009 Share Posted May 28, 2009 Perhaps this could be moved to the members area, for further discussion. Quote Link to comment Share on other sites More sharing options...
dude Posted May 28, 2009 Share Posted May 28, 2009 My mate took me out in his T51 R supra about 3 years ago on a local airfield and had done nothing to the aerodynamics. Got to about 160mph and the car was swaying like a boat and i dont think ive been more scared in a car my entire life. its like that rx7 on youtube trying to break the 200mph mark and gets caught by the wind and flips it 2 or 3 times in the air before destroying the car within seconds. lucky the guy had a rollcage but makes you think how much more you need to think about before gunning the top end. My car hit 189 mph from standing start in under a mile at bruntingthorpe and was rock steady seemed no different to doing 100 mph so I would say there was something very wrong with your mates car!!! The only reason it stopped at that speed was limiter that surfaced in the mines ECU. Quote Link to comment Share on other sites More sharing options...
bignum Posted May 28, 2009 Share Posted May 28, 2009 Why the hell would you want to reach 200 anyway, so you can tell your mates down the pub? Quote Link to comment Share on other sites More sharing options...
Lbm Posted May 28, 2009 Share Posted May 28, 2009 Would it be indecent to request 300mph? I think it's doable. Quote Link to comment Share on other sites More sharing options...
Dash Rendar Posted May 28, 2009 Share Posted May 28, 2009 Darryl got my car up to 198 (GPS) when it was his, and apparently that was pretty solid on the road. A very minor lift of the rev limit, and you're sorted. Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 28, 2009 Share Posted May 28, 2009 My car hit 189 mph from standing start in under a mile at bruntingthorpe and was rock steady seemed no different to doing 100 mph so I would say there was something very wrong with your mates car!!! The only reason it stopped at that speed was limiter that surfaced in the mines ECU. Approximately power were you running at the time? Built Auto? Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 28, 2009 Author Share Posted May 28, 2009 hi lads the car at the moment is rock solid 176mph garmin gps. there is another 7/9miles per hour left in her. So 185mph with the mods i have done hks exhaust and 2nd cat replacement pipe.hks type r intercooler kit.hks ecv6 boost controller 1.2 bar. hks ssqv recirculation. greedy fuel cut def. only need roughly another 20mph.Want to eventually go for hks twin turbos gt2835. first i want to see how fast the car can go on stock turbos with hks fuel rail. hksfuel pressure regulator. hks 1000c injectors.hks or titan cam gears with hks cambelt.greedy pulley set with uprated aux belt.twin denso standard fuel pumps. uprated fuel filter.fuel pulsation damper by pass. hks fcon v pro raise limiter to 7500rpm. could i run the uk turbos 1.37 bar /20psi.Told it should be close to 500bhp/prob 470 Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2009 Share Posted May 28, 2009 With stock or hybrid turbo's you're going to see at absolute maxium 450bhp with a hell of a lot of mods and running it on the edge of detting. Injector size doesn't matter once you get to 650cc (maybe even 550cc), they'll never max out on the stock or hybrid setup. What diff and gearbox do you have fitted? There's no way you'd get a stock turbo'd car to 200mph though. Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 28, 2009 Author Share Posted May 28, 2009 yes i know that and thanks for input v160 uk standard diff. should get close though will record topspeed on the sat nav. i read the standard internalls can handle 650 /700bhp. So i am thinking with the mods i have mentioned + clutch / rad / hks gt2835 twins it should get to 200mph what you think Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 28, 2009 Author Share Posted May 28, 2009 176 mph was at 345rwhp Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2009 Share Posted May 28, 2009 yes i know that and thanks for input v160 uk standard diff. should get close though will record topspeed on the sat nav. i read the standard internalls can handle 650 /700bhp. So i am thinking with the mods i have mentioned + clutch / rad / hks gt2835 twins it should get to 200mph what you think The drivetrain will take 1500bhp dependant on how hard you are on launches, the stock engine less so. With a big twin setup it will reach those sorts of speeds if you have a good and safe map to manage a very long WOT run. Personally I don't see the point in the very expensive twins when a single setup will deliver the same power and make it a more manageable car on the road (i.e. lower, faster spool). That is unless you want to go further than 600bhp which would ideally need a built engine. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 28, 2009 Share Posted May 28, 2009 176 mph was at 345rwhp They do 180mph stock, must be something wrong with yours. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 28, 2009 Share Posted May 28, 2009 I would much rather get to 160+ very quickly than have a very laggy set up to get to 200 eventually Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2009 Share Posted May 28, 2009 They do 180mph stock, must be something wrong with yours. I was going to say this too, but held back seeing as you mention it, with 345rwhp on a 6spd it will (should) do more than 176mph. I guess you ran of of runway A totally stock 6spd will do 176mph with "only" around 250rwhp, but needs a very long racetrack. Quote Link to comment Share on other sites More sharing options...
Scott Posted May 28, 2009 Share Posted May 28, 2009 The drivetrain will take 1500bhp dependant on how hard you are on launches, the stock engine less so. With a big twin setup it will reach those sorts of speeds if you have a good and safe map to manage a very long WOT run. Personally I don't see the point in the very expensive twins when a single setup will deliver the same power and make it a more manageable car on the road (i.e. lower, faster spool). That is unless you want to go further than 600bhp which would ideally need a built engine. I've got a suspicion he wants to stay twins and sequential He needs to do a bit of searching methinks. I know it is possible but its bloody complicated. As you say, single is a much more viable option. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2009 Share Posted May 28, 2009 I've got a suspicion he wants to stay twins and sequential Ah right, must of missed that bit! Well we all know the answer to that one Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 28, 2009 Share Posted May 28, 2009 If you really want to go 200mph get a good quality lump of rope and i will tow you up there:d:p Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 28, 2009 Share Posted May 28, 2009 A tuned supra to around the 500bhp mark does 200mph or Forza 2 at the ring. I should know as every time i see it when im learning the track for our trip in July i keep thinking to myself there is no way I will be doing that in my car Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 28, 2009 Share Posted May 28, 2009 if you really want to go 200mph get a good quality lump of rope and i will tow you up there:d:p lmao Quote Link to comment Share on other sites More sharing options...
jay_NW Posted May 28, 2009 Share Posted May 28, 2009 Interesting read. This is me doing 3/4 mile standing start. Looks like my speedo over reading there. Good video to show off though Quote Link to comment Share on other sites More sharing options...
twinkle001 Posted May 28, 2009 Share Posted May 28, 2009 why do you all go so fast and were do you drive most of the roads buy me only go up to 40 and the motorway only goes up to 70mph[GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2009 Share Posted May 28, 2009 why do you all go so fast and were do you drive most of the roads buy me only go up to 40 and the motorway only goes up to 70mph[GRIN][/GRIN] Track days Quote Link to comment Share on other sites More sharing options...
dan4 Posted May 28, 2009 Share Posted May 28, 2009 Quote Link to comment Share on other sites More sharing options...
dude Posted May 29, 2009 Share Posted May 29, 2009 If you really want to go 200mph get a good quality lump of rope and i will tow you up there:d:p I might even let you slip stream me to get him there!! Quote Link to comment Share on other sites More sharing options...
ellis Posted May 29, 2009 Share Posted May 29, 2009 why do you all go so fast and were do you drive most of the roads buy me only go up to 40 and the motorway only goes up to 70mph Why do you all have to go so fast and where do you drive? Most of the roads near me have a speed limit of 40mph and the motorway limit is 70mph! Now I can read it . . . . . and breathe!!!!! Quote Link to comment Share on other sites More sharing options...
