Pug 205 1.4 only running on 3 pistons.
edd_t
My little Pug project (see signature) is coming along nicely.
But at the moment its only running on 3 of the 4 pistons. I'm getting a good spark from all plugs and they are fireing in the correct order.
I'm borrowing a compresion tester this weekend, (or I should say dad is) to check somehting (sorry my knowledge now goes rapidly down hill)
But is there anything else I could or should be checking?
We have had the rocker cover off and the valves arnt moving much on the dodgy piston.
Cheers guys...
Well if its carb fuelled (which I assume it is) and has a spark then the only thing left really is low compression. Maybe the head gasket has gone?
oh i hope not :( doing the compression test this weekend so i guess that will confirm. yup its carb fuelled.
did you check the plug leads, cap etc ?
yup, all are good.
