_Shane_ Posted May 25, 2009 Share Posted May 25, 2009 Custom CP Pistons brand new in box. Spec is as follows 87mm CP Pistons 9310 Thick pin Locks are upgraded spiral locks that will not let the piston move. The CP groove is chamfered into the top to help with thermal expansion and oiling so there are no detonation prone hot spots. Pin fit means the pistons have been set exactly perfectly in the center by hand by CP so that there as straight as possible. The rings are also designed for street/drag duty and to ensure maximum sealing so HP is improved. Finally, the offset pin bore means the area above the pin is thickened so that the chance of ring movement/failure is decreased. Selling for 800 euros which at the exchange rate with xe.net is currently £700 Link to comment Share on other sites More sharing options...
_Shane_ Posted May 27, 2009 Author Share Posted May 27, 2009 bump Link to comment Share on other sites More sharing options...
JamieP Posted May 28, 2009 Share Posted May 28, 2009 I will offer £400, they cost £450 at MVP saving myself a little on the pistons and delivery costs. Link to comment Share on other sites More sharing options...
_Shane_ Posted May 28, 2009 Author Share Posted May 28, 2009 No thanks. Straight off the shelf CP pistons cost 450-500, these were custom made by CP and I paid extra for all the additional work i had done to the pistons plus there was a 3 month waiting list on these cheers Link to comment Share on other sites More sharing options...
JamieP Posted May 28, 2009 Share Posted May 28, 2009 No probs, my offer stands for a week before i order some:) Link to comment Share on other sites More sharing options...
DannoSupra Posted June 1, 2009 Share Posted June 1, 2009 Link to comment Share on other sites More sharing options...
_Shane_ Posted June 1, 2009 Author Share Posted June 1, 2009 Bump Link to comment Share on other sites More sharing options...
_Shane_ Posted June 27, 2009 Author Share Posted June 27, 2009 Bump Link to comment Share on other sites More sharing options...
_Shane_ Posted July 5, 2009 Author Share Posted July 5, 2009 Sold Link to comment Share on other sites More sharing options...
